Oxygen Sensor Problem
Old Jan 23, 2011 | 06:46 PM
wjones123's Avatar
Default Oxygen Sensor Problem
My car has started skipping and jerking really bad and it threw the #1 code which is o2 sensor so I replaced my o2 sensor last night and went out it did fine for a while but it started skipping again and threw the same code. It allows me to go only around 100 miles. So what could it be, I really have no idea what could be the problem. PLEASE HELP!!!!
Old Jan 23, 2011 | 06:53 PM
efjones9's Avatar
Default Re: Oxygen Sensor Problem
did u reset ur ecu?
Old Jan 23, 2011 | 07:01 PM
wjones123's Avatar
Well I think it resets itself when I turn it off because my hazards fuse is blown. Am I right on that? If not then I didn't.
Old Jan 23, 2011 | 07:41 PM
tonythetuner®'s Avatar
No you have to reset the ecu you can pull the hazard. Fuse under the hood or remove the neg cable off the battery. Also you said the fuse is blown so replace it see wat happens if it blows again wiring by the ecu could possible be messed up or the wiring for your hazard could be messed up
Old Jan 23, 2011 | 07:55 PM
wjones123's Avatar
I should add that when I fill up with gas it is fine but after about 3 gals is gone this problem starts again. Dont know if that means anything but I thought I should add it.
Old Jan 23, 2011 | 08:03 PM
crx_si-r's Avatar
are you running rich/lean? this could also cause the o2 to go bad.
Old Jan 23, 2011 | 08:07 PM
wjones123's Avatar
How can I tell?
Old Jan 23, 2011 | 08:28 PM
crx_si-r's Avatar
look at the o2 sensor. if its really dark/burt then your running rich. if its light/white then lean.
Old Feb 1, 2011 | 08:16 AM
wjones123's Avatar
The old one was a khaki color so I guess I'm running lean, right? How do I fix that?
Old Feb 3, 2011 | 10:40 AM
wjones123's Avatar
What do i do if it is running lean, this very annoying. I need to figure it out it got worse today. I went 88 miles on my last tank before I had to fill up again so somebody please help.
Old Feb 3, 2011 | 06:06 PM
Laserjock's Avatar
Whoah! you cant just skip over and ignore this!
The HAZ fuse is what powers the ECU!
Old Feb 3, 2011 | 06:14 PM
wjones123's Avatar
I guess I'll fix that then haha
Old Feb 3, 2011 | 06:51 PM
wjones123's Avatar
Could this be a fuel problem at all?
Old Feb 3, 2011 | 07:02 PM
Jockone's Avatar
Are you saying the car only did 88 miles on a tank full of Gas?
If that is all you are getting from a tank of gas then you have to be running really rich,you need to find out where the gas is going.
Old Feb 3, 2011 | 07:06 PM
wjones123's Avatar
I should have phrased that better I meant I could only go 88 miles or use 3 gallons out of that tank.
SC61HB
Oct 11, 2008 07:55 AM
JDM_SOHC
31
Aug 18, 2005 06:10 AM
t . b o z
May 1, 2005 11:40 PM
94gsr_vtc
Oct 24, 2004 01:06 AM
roc
May 7, 2003 06:53 PM
