Oil light on, knocking noise, no idea whats up.
Old Jan 15, 2011 | 05:31 PM
alex14's Avatar
Default Oil light on, knocking noise, no idea whats up.
88 civic sedan, D15b2 block with Z6 head. OBD1 and MPFI swapped.
I just got the car running for the first time a few days ago. I've driven it a total of about 150 miles sense I've had the car. I went to dinner tonight with some freinds, came out, pulled out of the parking lot and the oil light came on. checked the oil and its at the top of the upper dot. full. Drove it home about 6 miles and as I get into the neighborhood I start hearing a little knocking noise. I have no idea whats up or what it could be. No leaks anywhere, no power loss, the car did shut off twice when I was coasting in neutral but started right back up though.
car takes a while to start sometimes and I have to pump the gas a lot for it to start.
Any ideas what it could be?
Old Jan 15, 2011 | 05:44 PM
tonythetuner®'s Avatar
Default Re: Oil light on, knocking noise, no idea whats up.
Maybe your oil pump took a ****. no oil pressure = oil light will come on. The knocking your hear is probly a main bearing or rod bearing.
Old Jan 15, 2011 | 05:45 PM
D16SiHatch's Avatar
yup. should of stopped driving it immediately after the light came on until you determined for sure whether or not you had oil pressure.
Old Jan 15, 2011 | 05:49 PM
alex14's Avatar
Well, its not a major knock, if I replace the oil pump now am I good to go or is the damage already done?
Old Jan 15, 2011 | 05:51 PM
Damage is done if you hear it knocking already
Old Jan 15, 2011 | 06:00 PM
alex14's Avatar
Son of a bitch. I've been working on this **** hole for 4 months so I could go to a meet this monday.
I guess better now than when I'm driving down there.
Now that thats out...
Next question. I have the Z6 Block. its been sitting for about a month and has a light coat of rust on the cylinder walls. If I get an engine hone and re-hone it, should I be good to go? also, the Z6 block has a Light flywheel. Will that match up to my input shaft and clutch disc?
Old Jan 15, 2011 | 06:17 PM
Yes you could rehone the cylinder walls it should be fine. For the second part of your question idk I'm a dohc guy not a sohc guy lol. So I can't give ya answer for that
Old Jan 15, 2011 | 06:22 PM
alex14's Avatar
Thanks man.
Anyone else have an answer for the flywheel stuff?
Old Jan 15, 2011 | 06:26 PM
D16SiHatch's Avatar
doesn't matter what kind of flywheel it is, just need to have a clutch disc that matches the input splines on the transmission.
Old Jan 15, 2011 | 06:30 PM
jdmallstar86's Avatar
Ohh thats sounds not good !
Old Jan 15, 2011 | 06:33 PM
alex14's Avatar
So i can run the 212mm light flywheel from the Z6 with the clutch thats in the car now? what about pressure plates?
Thanks man.
ArkansasDave
Classic Hondas
Apr 23, 2011 04:23 PM
LS AzZkIkr
Apr 9, 2007 10:17 AM
GreenEHDriver
45
Dec 31, 2006 05:50 PM
boostedeghatch
31
Mar 2, 2005 12:58 PM
DAinfamousR
Nov 19, 2003 07:49 PM
