oil light
Old Nov 14, 2003 | 06:36 PM
DAinfamousR's Avatar
Default oil light
well here we go again.. one thing after another.. anyways chek this out.. sunday i got this killer kill i raced a 350 camaro ss on nos.. spanked his ***.. well i heard a noise coming from the car so we pulled the valve cover off and the gears jumped about 2 teeth each.. so now i crying because i think i bent some valves.. but thank god i didnt ANYWAYS my car had a oil leak it was the oil pump.. so we changed it out.. now the oil light is on.. when i start driving it the light start flashes on and off on and off.. any ideas.. thanks
Old Nov 14, 2003 | 06:38 PM
Rtype16's Avatar
Default Re: oil light (specRtunedgSr)
Porbably spun some bearings or something. I would put an oil gauge on the car and check to see if you have oil pressure.
Old Nov 14, 2003 | 06:44 PM
Default Re: oil light (Rtype16)
if i spun some bearing would the motor be noisy.. my boys hatched did that and you can hear i rocking???? motor is quite and still running good
Old Nov 14, 2003 | 08:54 PM
Boost2NA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">Porbably spun some bearings or something. I would put an oil gauge on the car and check to see if you have oil pressure.</TD></TR></TABLE>
, thats the only true way to see if what oil pressure you are getting.
Old Nov 14, 2003 | 09:02 PM
tony1's Avatar
Default Re: oil light (Boosted99Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted99Si &raquo;</TD></TR><TR><TD CLASS="quote">
, thats the only true way to see if what oil pressure you are getting.</TD></TR></TABLE>
And how do we know this Leonard??
Old Nov 15, 2003 | 11:35 AM
Default Re: oil light (tony1)
im trying to get a hold of a guage... no luck so far.. wheres the best place to chek for oil pressure????
Old Nov 15, 2003 | 02:10 PM
99B16Si's Avatar
yea definitely hook up a gauge and check that out. im assuming u have youre factory oil pressure sending unit hooked up right? try pulling out the small 12mm plug in the front passenger side of the head and run a tempory line and gauge to check it at idle and when u rev it up, obviously let the car warm up all the way so u can get accurate readings
Old Nov 19, 2003 | 07:49 PM
Default Re: (99B16Si)
well i got the result.. believe it or not there was no oil psi.. i say 5 if i was lucky.. ive been driven the car for four days.. yes i know im a fuking dumb *** .. i pulled the oil pan off and found the problem.. car running strong doesnt look like any damage occur.. thanks for all the input
rak511
Jul 4, 2013 11:17 AM
MUGEN_EG95
10
Oct 25, 2007 07:24 AM
b.d.racing
Aug 7, 2006 09:54 PM
boostedeghatch
31
Mar 2, 2005 12:58 PM
blackdelslo
Nov 13, 2004 11:07 PM
