View Poll Results: Should i keep this turbo for my build? is it a good turbo or not?
Keep it
77.78%
sell it or find a different turbo
22.22%
Voters: 9. You may not vote on this poll
Should i keep my PRECISION SC44 60 TRIM?? ANSWER MY POLL, YES OR NO!!!!!NEED OPINIONS
Old Jan 15, 2011 | 07:21 AM
xkrazyxjbrkerx75's Avatar
Icon3 Should i keep my PRECISION SC44 60 TRIM?? ANSWER MY POLL, YES OR NO!!!!!NEED OPINIONS
this is my build-
d16z6
Engine-
Vitara pistons- 8:5:1 compression
Eagle h Beam rods (tuner toyz)
Block guard
Ported oil pump
Head-
Bisimoto stage 3 camshaft
Supertech Valve springs and retainers
Ported and polished
5 angle valve job
Skunk 2 intake manifold
B series throttle body
Drivetrain-
S40 TRANS
XTD STAGE 3 CLUTCH
5 speed
I WANT TO BE SHOOTING FOR 350-400 HP....
I just picked up a precision sc44, Rebuilt 0 miles.-
Compressor Cover T04E 3" Inlet
Exhaust Housing T3
A/R .63
Exhaust Trim 63
has a 58mm compressor wheel with a 2.290" inducer and 2.950" exducer (60 trim). 5-bolt discharge side
IVE HEARD A LOT OF GOOD STUFF ABOUT THIS TURBO BUT THEN AGAIN PEOPLE TELL ME THAT IT WONT LAST LONG....ITS A JOURNAL BEARING......??? IDK IF I SHOULD KEEP IT OR NOT. VOTE FOR WHETHER I SHOULD KEEP IT OR SELL IT!!!
Old Jan 15, 2011 | 09:40 PM
civicgsrturbo32's Avatar
Default Re: Should i keep my PRECISION SC44 60 TRIM?? ANSWER MY POLL, YES OR NO!!!!!NEED OPIN
i think this question belongs more in the forced induction section.
Old Jan 15, 2011 | 09:45 PM
racebum's Avatar
true it does
i can't for the life of me understand why people spend that kind of money building a d16 rather than an 18c though
Old Jan 15, 2011 | 09:51 PM
Originally Posted by racebum
true it does
because d16 are a lot cheaper!
Old Jan 16, 2011 | 05:28 AM
DRAGLS's Avatar
Why don't you try maxing out the turbo before you move on to the next?
Old Jan 16, 2011 | 02:45 PM
FelixTuning's Avatar
Get a b18 and will be faster ... I think
Old Jan 16, 2011 | 11:17 PM
Gold DA9's Avatar
Run the turbo and see what you can get out of it. If you max it out then upgrade. No reason to spend more money when you dont have to.
Old Jan 16, 2011 | 11:24 PM
what size injectors should i gettt
Old Jan 16, 2011 | 11:35 PM
Gold DA9's Avatar
what type of fuel is going to be used? What fuel pump(s) used?
Old Jan 16, 2011 | 11:43 PM
racebum's Avatar
mmmm little bit in the head, BUT, bottom ends are pretty similar. aftermarket pistons and rods..ehh..toss up
the head is totally true but you guys are using spendy *** **** to crack 10s anyway. what's a few hundred to get a much better head and a displacement increase?
Old Jan 17, 2011 | 07:56 AM
pump gas , walborro 255 fuel pump
Old Jan 17, 2011 | 02:53 PM
Gold DA9's Avatar
Do you plan on running e85 at all? If so that would also make the injectors you want to buy larger?
xkrazyxjbrkerx75
Jan 16, 2011 04:57 AM
xkrazyxjbrkerx75
Jan 15, 2011 10:00 AM
NyQuiL
Dec 9, 2003 07:41 PM
DubyaAye
Apr 21, 2003 07:13 PM
