What turbo trim for me?
99 Ls block and head
golden eagle sleeves
Arias stnd bore 8.5:1 pistons
Eagle rods
Built head.
Going to be tunned on the e-manage.
Im trying to shoot for around 370+ on pump gas, and even higher on high octane but that will rarley happen. I want to go with a precision turbo, can anyone recomend a good size to go for? I see alot of people on here rockin sc61 but that seems a bit to big.
Eagle rods
Built head.
New User
Re: What turbo trim for me? (NyQuiL)
SC50
T3/04E
.63 a/r
stage 3 exhaust
50 trim compressor
Such a versatile compressor, so very often over looked by the honda camp flows almost as much as a 57 trim with faster spool.
T3/04E
.63 a/r
stage 3 exhaust
50 trim compressor
Re: What turbo trim for me? (VaporTrail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VaporTrail »</TD></TR><TR><TD CLASS="quote">SC50
T3/04E
.63 a/r
stage 3 exhaust
50 trim compressor
Such a versatile compressor, so very often over looked by the honda camp flows almost as much as a 57 trim with faster spool. </TD></TR></TABLE>
Dont forget more effcient than a 57 trim too.
T3/04E
.63 a/r
stage 3 exhaust
50 trim compressor
Re: What turbo trim for me? (Arturbo)
YES! finally someone suggests the 50 trim.... i think it's a perfect choice for the LS motor.. responsive, little lag, makes good power
New User
Re: What turbo trim for me? (2lowintegra)
I like the 50 trim for just about any 4 cylinder. All you do is change the exhaust side around a little to suit different engine sizes/powerbands/desired hp levels. It's quite versatile.
New User
Re: (NyQuiL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NyQuiL »</TD></TR><TR><TD CLASS="quote">hp limit on it?
efficency?</TD></TR></TABLE>
its rated to flow 47lbs/min but we used it on a SR20DET and it made 470whp... so it's probably more like 49-50lbs/min
Moderator in Chief
Re: (VaporTrail)
Just to clarify: Both turbos in question both have a .63AR?
When your talking about the 50 trim do you mean the Precision SC50
and SC34 for the 57 Trim?
Would it be correct that the SC34 with a .63AR and a 57trim is the most common Precision T3/T04 turbo for Honda street cars?
JDM turbo DC
11-19-2005 06:13 PM
