power steering
Old Sep 24, 2002 | 07:55 AM
kuelerz's Avatar
Default power steering
when you do a gsr swap into a civic 98 how do you hook up the power steering feed line. the line the bolts onto the top of the pump. do you need to buy a gsr power steering line or can you use your stock civic pump?.
Old Sep 24, 2002 | 09:27 AM
poison's Avatar
Default Re: power steering (kuelerz)
have you tried using the civic pump with the civic bracket and hooking up the line that way?
You might need to purchase a GSR power steering up since I don't believe it will quite reach the new PS pump on the gsr motor.
Old Sep 24, 2002 | 10:16 AM
97EXhybrid's Avatar
you have to use the B series pump, bracket and high pressure line. You'll have to get a hydraulic shop to couple the b-series high pressure line to your Civic line. Look in the yellow pages for companies that work on tractors and construction equipment.
Mainsubject
14
May 4, 2013 03:34 PM
mister_ej2
Apr 5, 2008 06:17 PM
boostincoupe
Jan 23, 2007 01:15 PM
hondacivic2nv
15
Nov 28, 2006 09:21 AM
Blk00EJ8
Jul 25, 2006 07:36 PM
