Is it possible to bend a subframe back into place?
Civic 00...possibillity subframe is bent pushing the lca about an inch towards the back of the wheel well on the drivers side.
Can I bend it back? Is there a shop that would do something like that or would they all say no hope you have to replace it?
Methods of bending it back? I'm open to all caveman-hammer-esque suggestions that might have worked for anyone else...theories...he said she said this worked ideas.
It could be possiable. if its off an inch thats a little scary when they do bend it back that part will always be a weak point. you can order a new subframe its not to hard to install.
Front subframe...and I found a write-up on it...and he said it took him 8 hours....looked like a helluva process.
I plan on replacing it eventually but for right now if I can bend it back to close to normal...then I'll be happy till I have more time and money. I'm primarily trying to avoid any extra tire wear if I can...right now if I hit a bump it hits the inner fender...as well as the alignment. Alignment would be pointless right now until this issue is close to fixed. Bad alignment = more tread wear = no bueno.
http://repo.jackmoves.com/v/erik/album106/album139/
That's the DIY write-up I found...is that a good guide? It said it took him 8 hours to do it.
If you know of a better write-up or anything you'd do different than that please let me know if you have time to look over that.
Thanks for all the input.
There is no way that takes 8hrs that guys is slow lol. You just un bolt the rear engine mount. support the engine with a jack. unbolt the lower ball joints and steering arm and suspenson from the LCA. On the Inside of the car unbolt the 10 mm bolt that connects the steering column to the steering rack. apply pressure to the subframe with a jack in the middle. brake all tghe bolts loose and remove them. then slowly lower the sub frame down. bam! then just put the new one in.
Thanks ron and h22aferio...on paper that sounds simple enough...I will be replacing tie rods inner and outer...all ball joints including my upper control arms...so I suppose id be taking half of that stuff anyways..
No Prob man! good luck. let me know if you need help with anything. it looks like that guy took everything apart lol.
Lmao...well after the accident I was in...my steering wheel is a little off anyways...comes hand in hand with the ****ed up alignment and whatnot. Good tip about the wheel though...
Is it hard swapping all the parts over to the new subframe that are connected when you pull it out...i.e. steering components?
BIG QUESTION: As mentioned earlier I'm replacing the UCA, all ball joints, inner and outer tie rods, and forgot to mention earlier I need a new axle...but what else would be good to replace "while i'm down there"...I think i remember earlier seeing an improvement in steering if you replace a steering bushing of some sort? Anything else?
Thanks again for all the help everyone...and it's comforting knowing that this won't be an 8 hours job...that could make for a shitty weekend.
Now would also be a good time to look into bushings.
It is the best time, everthing will be apart, well almost, and you will need an alignment after the work is complete.
Find a good pick and pull yard I got a complete front sub frame for $30 swapped it out in under 3 hours and that was with a little fab work since i got one from a car that was a manual rack.
TwoFaced
Suspension & Brakes
Jan 10, 2011 03:43 PM
Corksil
10
Sep 13, 2009 05:00 PM
fw190bvi
Sep 18, 2006 08:13 PM
