strange noise from civic at random times. not sure how to diagnose
Old Jan 5, 2011 | 09:30 PM
nospoolDC2's Avatar
Default strange noise from civic at random times. not sure how to diagnose
I have a 95 civic cx with 173,XXX miles. I got it about a month ago. It would once and a while make a slight squealing noise when turning or accelerating, but I didn't think much of it. Today it started getting louder and more frequent, and it squeals also when I rev match downshifts, specifically when the motor is revving up freely with the clutch in. It seems to occur at more random times now so I'm not sure where to start. Also just for reference the car is bone stock. Any ideas?
Thanks Guys.
Old Jan 6, 2011 | 04:30 AM
WhiteOnRice's Avatar
Default Re: strange noise from civic at random times. not sure how to diagnose
If it's doing it w/o load (clutch in) just have a buddy listen under the hood and try getting it to do it again. It's probably just a belt and does it around a certain rpm range.
Old Jan 6, 2011 | 05:10 AM
nospoolDC2's Avatar
It seems to occur at inconsistant rpm ranges. It does not occur when the car is stationary in neutral, even when you rev it. Could this be a clutch related problem?
Old Jan 6, 2011 | 05:49 AM
grumblemarc's Avatar
The Grumpiest
Squealing noises are usually belts. Are you sure it's squealing and not a high pitched grinding noise?
Old Jan 6, 2011 | 06:31 AM
nospoolDC2's Avatar
Sounded more like a squealing noise, but I'll listen closer next time I'm in the car. If it were a high pitched grinding noice, what would your suggestion be?
Thanks
Old Jan 6, 2011 | 06:42 AM
The Grumpiest
Tensioner pulley. But even then it should be constant and not intermittent.
Old Jan 6, 2011 | 07:20 AM
Former User's Avatar
If you hear the noise only when the clutch pedal is depressed, the clutch throw out/release bearing may be bad.
Old Jan 6, 2011 | 07:43 AM
nospoolDC2's Avatar
^^ This is what I wasthinking, but it also makes the noise when it is not depressed. It is louder and more frequent when it is depresseed though.
Old Jan 12, 2011 | 05:41 AM
nospoolDC2's Avatar
any more ideas guys? it is now squealing even after i let off the clutch when the cars in neutral, untill i rev it again. im starting to think its a belt now.
Old Jan 12, 2011 | 06:00 AM
The Grumpiest
How old are the belts?
Old Jan 12, 2011 | 06:44 AM
nospoolDC2's Avatar
older that sh*t for all i know. they were on the car when i got it.
Old Jan 12, 2011 | 07:29 AM
vtechjunkie's Avatar
If it were the belts, it wouldn't be "at random rpm". It would be when it was cold, or once it warmed up. Either, or, rarely both. As for it being the throwout bearing, how is the pressure plate feeling. Does the engagement start at different depression levels ever? That is also indicative of a bad bearing.
Old Jan 12, 2011 | 07:34 AM
nospoolDC2's Avatar
well its usually at lower rpms. and it occurs more when its cold, but occasionally when its warm also. its weird. and no, it always engages at the same spot.
TYBG
Mar 5, 2015 11:10 PM
ElFin
Jun 4, 2014 06:44 AM
UpAndComin
Transmission & Drivetrain
Feb 17, 2009 08:25 AM
looneytoonz
Nov 10, 2007 06:14 AM
pli
Nov 20, 2006 05:12 PM
