EG8 not starting
Old Jan 5, 2011 | 01:45 PM
fa5VSeg8's Avatar
Default EG8 not starting
hi i have an eg8 i did a tune up on. i messed up the firing order and set it back to what its supposed to be, new dizzy rotor and cap and coil. Coil was fried. it tries to start now but every 3 cranks it stalls and strains. any thoughts?
Old Jan 5, 2011 | 01:47 PM
Former User's Avatar
Default Re: EG8 not starting
Is there bright white spark at all four plugs? Any CEL codes?
Post pictures of the plug wire firing order on the cap. Cylinders are ordered 4-3-2-1 as you go from the distributor to the timing belt.
Old Jan 5, 2011 | 02:19 PM
fa5VSeg8's Avatar
thats exactly how its set up
Old Jan 5, 2011 | 02:21 PM
fa5VSeg8's Avatar
NO CEL, but i did fry the coil on the dizzy, replaced it. a puff of smoke came out...its a d15b7. there is a connector with two wires above the dizzy that when unpluged, the motor turns just fine without hesitation just no ignition
Old Jan 5, 2011 | 02:22 PM
fa5VSeg8's Avatar
could the timing be off? is there a way to jump the timing without the car running?
Old Jan 5, 2011 | 02:23 PM
Again, is there bright white spark at all four plugs?
Old Jan 5, 2011 | 02:29 PM
fa5VSeg8's Avatar
not sure at this point...am i supposed to see a spark come out of the wire? or do i need to pull a plug and ground it out?
Old Jan 5, 2011 | 02:31 PM
fa5VSeg8's Avatar
at the wires no spark
Old Jan 5, 2011 | 03:52 PM
How are you testing for spark? If done incorrectly, you'll blow the coil. Click the Spark link in my signature.
Old Jan 5, 2011 | 09:05 PM
fa5VSeg8's Avatar
had the coil and the igniter tested. both failed. got a new dizzy...runs great now starts on one turn
gerbsgsr
15
Dec 28, 2015 08:46 PM
e-roc88
Nov 1, 2010 03:39 PM
ludemach23
10
Oct 11, 2009 01:11 PM
srt4pilot
33
Jun 22, 2009 09:36 PM
civickiller
Feb 21, 2007 03:11 PM
