**NEED HELP W/ LS-V SWAP INTO DEL SOL**
Old Jan 5, 2011 | 01:50 AM
whokidd's Avatar
Default **NEED HELP W/ LS-V SWAP INTO DEL SOL**
Okay, I am going to buy a ls-vtec motor, and going to drop it into my 95' del sol-s. I was wondering what do I need to do the swap.
THIS IS WHAT MOTOR WILL COME WITH:
head: b16a
block: b18b1
trans:b16a
goodies:
intake mani:type r
type r throttle body
spoon gasket
10mm spark plug wires
new spark plugs
DC headers
new clutch
new flywheel
new head gasket
gsr cams n gears
shift linkage with short shifter
new radiator n resavor
Does not come with axels, wire harness and ecu
So what axels, wire harness and ecu do I use? Also what else do I need to do the swap?
Thank you in advance for your help
Old Jan 5, 2011 | 02:34 AM
ricky00's Avatar
Default Re: **NEED HELP W/ LS-V SWAP INTO DEL SOL**
u will need a vtec harness 94-01 integra axles n a vtec ecu that u might need or might not to chip to run it but its best if u do..
Old Jan 5, 2011 | 08:18 AM
Cresendo's Avatar
make sure it the del sol b series shift linkage
Old Jan 5, 2011 | 12:19 PM
whokidd's Avatar
So the only shift linkage I can use is from a b-series Delsol? Is there anything else that I need?
Old Jan 5, 2011 | 12:26 PM
8YourV8's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-ls-vtec-truth-behind-power-2587855/
Read and learn
Searching helps too
Old Jan 6, 2011 | 12:42 PM
whokidd's Avatar
Yea I stumbled over that thread the other day. Not so sure about going ls-vtec now.
Old Jan 14, 2011 | 11:23 AM
whokidd's Avatar
Should I still buyh this set up for 900? Or spend a little more and get a gsr?
cody_sandlin
Aug 9, 2013 05:19 AM
da_driver_15
Dec 25, 2010 12:23 PM
roque-pr
19
Mar 24, 2010 05:21 PM
spunky424
Aug 15, 2006 08:25 AM
