wtt fully built low compression d16z6 by rs machine
for a b series swap if not gsr
u take of my swap and put urs on my car will help u
d16z6 block the block is sleeve from rs machine to 75.5mm with arias low compression piston for turbo.. eagle rods. all race bearings. turbo camshaft from crower. titimium retiner stainless valves ported & polish head. rev could be raise up to 9000 or 10000rpm. your good to go..just put turbo and tune it...motor is good to boost up to 40 pounds no problem
evrything is built for turbo
comes with stage 4 clutch a s20 tranny perfect conditions no grinds
still in the car running
so u can test it out
skunk 2 manifold
call or text 562 382 4389
i paid more than a b series for this motor to get done at rs machine shop
its in perfect conditions
motor is good to be rev at 10000 rpm
skunk 2 manifold
Purfect
37
May 18, 2013 03:26 PM
xkrazyxjbrkerx75
Nov 28, 2009 08:54 AM
