Civic idle issue..
Old Jan 2, 2011 | 10:29 AM
SignorSchnitzel's Avatar
Default Civic idle issue..
Hey guys I got a 1997 Honda civic ex, I recently cleaned my throttle body and tightened my throttle cable (to spec) to fix an unsmooth Acelleration issue. But now what Happens is when I come to a stop or shift into neutral, it only drops down to 1500 rpm where it should drop to 750-800ish I belive. Also when I come to a complete stop it will sit at1500 rpm as I mentioned before and then after about 5 second it drops down to the correct idle rpm.... This annoys me I want to fix it hahaha
Old Jan 2, 2011 | 11:11 AM
Former User's Avatar
Default Re: Civic idle issue..
The throttle cable should be adjusted to have ~1/2" of free play.
Old Apr 20, 2011 | 02:18 PM
frankenghia's Avatar
check your tps also. I had the same problem. My tps was out of tolerance. I adjusted it and the problem went away. Just a thought.
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
AngeloPappas900
Apr 25, 2011 06:55 AM
emooheo
Mar 23, 2007 02:34 PM
shooitzlinh
Jan 8, 2005 09:52 PM
eknine
Jul 10, 2003 08:36 AM
