About pauter rods - edm?
I currently use pauter rods and I did not get this option. there are several rod manufacturers who do not offer this option so I don't know how important this is. honda engines are oil pressure happy and there is no need to "pressure feed" the wrist pins because there is plenty of oil getting to them already..
Pressure fed oil to the piston pins is only required for engines running high levels of crankcase vacuum. In the engines with low crankcase vacuum it is possible to starve the pins of lubrication.
Totally not required for normal applications.
EKB18BPR3
Oct 30, 2004 09:30 AM
