93 EG still wont start
Old Dec 30, 2010 | 11:10 AM
91efbluehatch's Avatar
Default 93 EG still wont start
i got a new battery fuse and put it in. everything seems fine.
try to start it, and it turns but doesnt start up.
dash lights come on and everything.
fuel pump, injectors, etc. are working.
i noticed thought that there is no 38 fuse on the underhood fuse box?
would this cause it not to start?
need help ASAP. trying to get everything fully operational today.
Old Dec 30, 2010 | 03:31 PM
Default no spark from dizzy
so ive had no starting problems with my 93 eg si all day.
checked fuses, fuel pump, injectors, etc. work.
battery is good.
had my brother sit in the car while i pulled off a spark plug wire, and had him crank the car while placing the wire near metal.....AND.....nothing.
i did this all 4 times.
should i just use another distributor and see if the problem is fixed, or is there i way i can rebuild it.
i do not have a multimeter on hand, or a tester.
Old Dec 30, 2010 | 04:05 PM
4dregDC's Avatar
Default Re: no spark from dizzy
Ur coil might be bad u can take it apart n autozone can check it for u
Old Dec 30, 2010 | 04:11 PM
nahnah05's Avatar
probly a coil issue had the same issue.
Old Dec 31, 2010 | 11:10 AM
changed the coil in the dizzy and now i do have spark.
motor still turns, so now i think it may be injectors, or spark plugs.
Old Dec 31, 2010 | 01:18 PM
Default Am i timing it wrong?/
is there any way you can time a z6 wrong??
i know the cam gear should say up, the two marks on the timing cover are aligned, and the bottom one as well.
i just cant figure out why my eg wont start.
fuel rail is getting fuel, the pump primes, dizzy gives spark. replaced the coil in the dizzy. firing order is correct.
any idea?
Old Dec 31, 2010 | 01:24 PM
jdmwannabee's Avatar
Default Re: Am i timing it wrong?/
is it cranking?
what did you do that required you to reset the timing?
Old Dec 31, 2010 | 01:26 PM
the motor will turn and turn but it wont start. it sputtered twice for the first time about 15 min.
i had to put another dizzy on it. and it is a z6 dizzy.
i also took the same injectors out of a working car and put em in the fuel rail and still nothing.
Old Dec 31, 2010 | 01:51 PM
MonkeyMagic's Avatar
what happened that made it stop to begin with?
just didn't start one day?
Old Dec 31, 2010 | 01:55 PM
Former User's Avatar
Default Re: 93 EG still wont start
Only one thread per topic is allowed. Three related threads merged.
Old Dec 31, 2010 | 05:02 PM
93blackcivic's Avatar
Do this and forget all others!
http://techauto.awardspace.com/ignition.html#flowchart
__________________
Old Dec 31, 2010 | 05:11 PM
phaphon's Avatar
and also check your firing order
Old Dec 31, 2010 | 05:44 PM
ignition timing is correct.
had laptop out there while i did it.
replaced the coil and i have spark.
replaced injectors, and fuel rail.
i am getting fuel to the rail, and to the injectors.
going to check the plugs and compression test tomorrow.
also noticed something.
driver rear tail light stays on, and interior light doesnt come on when driver dore is opened.
and the dash lighting switch doesnt work.
Old Jan 1, 2011 | 07:13 AM
fonkernuckle's Avatar
RonJ gave me a great clue a while back(lurking on a thread) to what my problem was which I finally fixed yesterday: Cel should come on then go off when key is turned(not cranking on but just on-when all indicators light) if cel stays on then check the ground going to the thermostat, if good and still have the same prob then ecu could be the problem--I had times when my cel would stay on=no start--I would wait then sometimes it would go off and I could start my car--thought it was the ignition switch and this problem persisted until yesterday when i changed my ecu. thanks RonJ
Old Jan 1, 2011 | 08:19 AM
Rok_Stok's Avatar
It could just be a bad starter. When the starter went out in my d16z6 it would still crank just not start. Junk yarded it.
Old Jan 1, 2011 | 10:49 AM
Eg started.
had to take the dizzy off, and retime it again.\
had it set for number 2 instead of number1.
cranked up just fine.
jOnW89
10
Jul 15, 2009 02:07 PM
itr909
19
Apr 21, 2009 06:07 AM
93TEGGYgs
Oct 21, 2008 04:32 PM
rizzob
Aug 21, 2006 09:46 AM
terribl3jon
10
Aug 26, 2004 12:01 PM
