99 Civic SIR - Electrical Power Loss
Old Dec 30, 2010 | 06:57 AM
Ayeso's Avatar
Default 99 Civic SIR - Electrical Power Loss
Hi Everyone,
Just looking for more things to check. Im currently at work but when I get home I will look at a few things. Here is the issue.
For the last couple weeks, when I drive my car I will be idling at a light and SOMETIMES I will lose electrical power it seems (Tach dies, stereo dies, dash lights die) I rev the engine and everything comes back alive, let it idle for a bit and its fine again and may not happen again that day.
It seems to be more frequent lately though, today I had to hold it at 1500rpms because as soon as I let it idle on its own it would lose power.
I plan to check the basics, belt tension, terminals, voltage on alternator and battery. Any other ideas? I have a spare battery I could swap in...
Its also very cold here currently around -25c.
Car has a stock B16a2, I think thye only mod would be exhaust, intake and a underdrive pulley(Which came with the car and I plan to remove once I find a stock one)
Thanks,
Old Dec 30, 2010 | 07:03 AM
ej2redcoupe's Avatar
Default Re: 99 Civic SIR - Electrical Power Loss
it sounds more like a alternator problem to me and being that its super cold if you dont mind me asking what weight oil are you using on the motor??
Old Dec 30, 2010 | 07:07 AM
Ayeso's Avatar
Thats what I was thinking as well.. I know the belt on the alternator is pretty grungy looking. I was hoping to avoid replacing it until I swapped crank pulleys.
5w30
Same as I normally run in my other civics here. Never have any real issues with cold starts or louder then normal ticking.
Old Dec 30, 2010 | 07:16 AM
Former User's Avatar
Sounds like a classic low idle problem. Any CEL codes? Have you cleaned the IACV (and FITV if you have one)?
Old Dec 30, 2010 | 07:20 AM
Ayeso's Avatar
No cel codes, idle is hovering around 900-100 when it idles normal which is 95% of the time. I turned it up a bit as when its REAL cold, when it first starts it has trouble running when its -35+
Havent cleaned the FITV/IACV but it doesnt seem to be the same as that, I've had that issue numerous times but it is something I will keep in mind to check as well.
Old Dec 30, 2010 | 11:19 AM
F4MzEkSOL's Avatar
u needs a motor warming device
Crossbreeder
Feb 5, 2010 07:36 AM
MzStreetracer
Mar 6, 2007 08:38 PM
bennyDA
Sep 23, 2006 11:47 PM
aznsins88
Sep 13, 2004 09:13 PM
TurboTurtleGSR
May 27, 2003 02:17 PM
