How high can you boost on a 00 gsr b4...
Old Sep 23, 2002 | 04:16 PM
Andrew 825SM's Avatar
Default How high can you boost on a 00 gsr b4...
b4 the ecu starts throwing codes?
Old Sep 23, 2002 | 04:24 PM
Mr. Vapor's Avatar
Default Re: How high can you boost on a 00 gsr b4... (NHB Fighter)
usually 30-32 lbs....right around 32lbs it throws code 711 "to much pressure in intake, danger to welds"
Old Sep 23, 2002 | 04:26 PM
01geeser's Avatar
New User
Default Re: How high can you boost on a 00 gsr b4... (NYb16)
hahahhahahha
Old Sep 23, 2002 | 04:33 PM
Default Re: How high can you boost on a 00 gsr b4... (01geeser)
oh really....then I have nothing to worry about!! No but really, how high because the 2000 gsr with obdII "enhanced" has a lot of restrictions and I'm gonna be turning up the boost quite a bit.
Old Sep 23, 2002 | 04:36 PM
Cow's Avatar
Cow
Uh.. on a stock MAP sensor I believe any sign of boost will throw a code, someone correct me if I'm wrong? Otherwise, you'll need a 3 bar MAP sensor after like 11 lbs. or so.
Old Sep 23, 2002 | 04:40 PM
98civicEX's Avatar
Default Re: How high can you boost on a 00 gsr b4... (Cow)
Old Sep 23, 2002 | 04:51 PM
Mr. Vapor's Avatar
Default Re: How high can you boost on a 00 gsr b4... (98civicEX)
stock map sensor cant see even a hint of boost....need the missing link. if you want to boost over 12psi you need the GM 3 bar map sensor.
Old Sep 23, 2002 | 05:20 PM
dustin's Avatar
That's pretty risky
You're liable to blow the welds on the intake
Old Sep 23, 2002 | 05:22 PM
Mr. Vapor's Avatar
Default Re: How high can you boost on a 00 gsr b4... (dustin)
dustin, see above response hehehe, code 711
Old Sep 23, 2002 | 05:25 PM
dustin's Avatar
Ah... hehe.. See I'm just confirming your good info
Old Sep 23, 2002 | 06:49 PM
the max i plan to be boosting will be around 12 wiht spiking up to 14 or so because I have a mbc so would I need this GM 3 bar map sensor? And if I do where can I get one?
foxdie
Feb 24, 2013 04:22 PM
SOHCex20
Aug 18, 2005 08:49 AM
wc
Aug 4, 2003 10:35 PM
platinum00
Jul 25, 2003 09:16 AM
platinum00
Jul 24, 2003 08:02 AM
