Uberdata questions
Old Aug 2, 2003 | 06:32 AM
wc's Avatar
wc
Default Uberdata questions
I downloaded Uberdata from a thread a few days ago (and I can't find that thread now) and I have a few questions:
1. How does Uberdata allow boost? Is the boost "code" generated by Uberdata or does the base .bin already have this "code"?
2. Does Uberdata allow the control of the GSR secondary intake runner?
Thanks.
- wei
Old Aug 2, 2003 | 09:11 AM
1.8T_EG's Avatar
Default Re: Uberdata questions (wc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wc &raquo;</TD></TR><TR><TD CLASS="quote">
1. ...uberdata allows the ecu to read boost from the map sensor instead of throwing a code 3 CEL... the boost code is automatically generated, you can see it in the last 5 columns...
2. ... dunno about iab's... but i would guess that if you used a p72 you would be fine... but if i were you, i would look into a skunk2 manifold...
Old Aug 2, 2003 | 12:02 PM
Joseph Davis's Avatar
Default Re: Uberdata questions (1.8T_EG)
All the VTEC code used by Uberdata is based on P72, with IAB control.
Since Uberdata was set up to work with P72/P75 code, I had to port P06, P28, P30, P13, and P12/P14 maps over to it so people had basemaps.
Old Aug 2, 2003 | 12:05 PM
Burke's Avatar
Banned
Default Re: Uberdata questions (J. Davis)
just wanted to say uberdata rocks and i am VERY PLEASED with it right now. Blake the developer also rocks and so does J. Davis. THANKS GUYS!!!!
Old Aug 2, 2003 | 12:30 PM
wc's Avatar
wc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">All the VTEC code used by Uberdata is based on P72, with IAB control.
Since Uberdata was set up to work with P72/P75 code, I had to port P06, P28, P30, P13, and P12/P14 maps over to it so people had basemaps. </TD></TR></TABLE>
Are you saying then the .bin generated by Uberdata can only be run on a P72/P75 ECU?
- wei
Old Aug 2, 2003 | 01:55 PM
Ovaltine's Avatar
Where can I download uberdata? It's not even in the recent/archived search.
Old Aug 2, 2003 | 01:58 PM
Mr. Softee's Avatar
Default Re: Uberdata questions (Ovaltine)
im having serious ******* problems with 3 bar and uberdata. other than that im quite happy.
Old Aug 4, 2003 | 09:29 PM
wc's Avatar
wc
Anyone know if .bin generated by Uberdata can only be run on a P75 ECU? Because I don't see a disable for the knock sensor. Thanks.
- wei
Old Aug 4, 2003 | 09:48 PM
turbod16y8's Avatar
Default Re: Uberdata questions (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">just wanted to say uberdata rocks and i am VERY PLEASED with it right now. Blake the developer also rocks and so does J. Davis. THANKS GUYS!!!!</TD></TR></TABLE>
same here!!
Old Aug 4, 2003 | 10:35 PM
Default Re: Uberdata questions (turbod16y8)
Knock sensor is only an issue with the VTEC basemaps. I'll correct that with the VTEC basemaps eventually, or maybe Blake will fix his stupid tuner app first.
OBD1 ECUs and OBD1 code is interchangeable, more or less. The P75/LS basemap also runs P74 and OBD1 PR4, etc.
Ben Huynh
Oct 31, 2013 09:17 AM
HondaMotive
Engine Management and Tuning
Oct 27, 2011 09:21 AM
shadowdawn
Sep 30, 2002 05:59 PM
Andrew 825SM
Sep 23, 2002 06:49 PM
