FI newbie questions
Old Dec 27, 2010 | 09:32 AM
laopadak303's Avatar
Default FI newbie questions
Hoping to get some questions answered.
My current project is a B18C swapped 96 Civic coupe. Power goals are 250-300 Whp on stock internals (will be doing a rebuild on the motor prior to turbo). Will be using a cometic head gasket, ARP head bolts & block guard.
Will likely also upgrade the Greddy downpipe for a custom 2.5" due to its poor flow characteristics.
Recently picked up a used Greddy TD05-18G kit w/ JDM sport intercooler/pipes & knock off HKS BOV.
What is the stock wastegate actuator set to?
I've heard 7-8psi and 11psi. Can't seem to get a confirmed answer.
If the wastegate spring is upgradeable, any suggestions on where to get an OEM replacement?
There's a nipple on the upper cold side which is installed right after the BOV, is this where the line from wastegate of turbo goes to?
If I wanted to increase the boost pressure (looking to run 9-10psi), I should be able to put a MBC in between the wastegate and nipple on upper cold side pipe and control the amount of boost, correct?
Any solid advice is greatly appreciated.
Thx.
Old Dec 27, 2010 | 01:43 PM
Hondaruss's Avatar
Default Re: FI newbie questions
You can Use a OEM honda head gasket, no need for a block guard the sleeves will hold it with a proper tune.
That wastegate is a common wastegate style, you can find a replacement gate at atpturbo.com
Most likely yes this can be used for a reference for your wastegate
You can put in a MBC inline from the feed to the wastegate and that will control your boost.
Thx.
Old Dec 27, 2010 | 04:32 PM
Thx Hondaruss, also found a few more useful links/reads on MBC's, the 18G etc so I think my questions are answered.
Cloneufc
May 5, 2009 04:59 PM
PooOnMyShoe942
Sep 30, 2005 04:50 PM
B16Civic93
May 3, 2005 05:19 PM
spike
Dec 28, 2003 09:14 AM
Ricey McRicerton
Sep 23, 2003 04:04 AM
