fuel fitting adapters
Old Dec 23, 2010 | 11:40 PM
Civic89stdB16's Avatar
Default fuel fitting adapters
how is everone using the walbro intank and then using a -8 or -10 feedline right outside the tank. An how can i make a -6 or -8 return line go to the stock tank. all this is going to be done with a 044 buy the fuel rail. Please post picks and where u got the fitting or how u converted it. thanks
Old Dec 24, 2010 | 04:56 AM
96 GSR-T's Avatar
Default Re: fuel fitting adapters
I welded -6 & -8 bungs on top of the stock steel pump hanger... rather easy
Old Dec 24, 2010 | 12:27 PM
thanks was thinking of that after i posted it. i didnt know if there was a adapter banjo fitting to -8 or -10. thanks 96 gsr-t
Old Dec 24, 2010 | 01:30 PM
Adriano's Avatar
You can buy a metric-to-8an adapter and use a 90 fitting. I've done it before, the only downfall is that you can really use that metal cover anymore. The fittings will hit it.
Adriano
Old Dec 24, 2010 | 02:10 PM
Divers's Avatar
They make a banjo to -8 fitting. I believe summit sells it, or just use two fuel injector clamps and flare the hard line. As for the return, I like to use the old factory feed line as the new return. It works well and saves on buying more braided hose and fittings.
Old Dec 24, 2010 | 06:31 PM
tony1's Avatar
Or save your money, if you're using a walbro feeding a Bosch pump, the factory lines are more than sufficient.
Old Dec 24, 2010 | 07:19 PM
IN VTEC's Avatar
I used goodridge 776-08-m14 m14 to -8AN banjo adapter. The cover still fits over the banjo adapter.
I had to hammer down the stays and avoid overtightening the banjo bolt until I can find a longer one.
Old Dec 24, 2010 | 09:52 PM
yeah im tying to make well over 650whp on e85 with the intake walbro to -8 feed and inline 044 with ford racing 1680cc injectors. both pumps will be on boost a pumps. lmk what u think t1 tony. if i have things u think i should change to make my power goals then lmk what it is. thanks
btw: the intank will probally be switched to the areomotive 340 intank when it comes out.
carlos8
Jun 8, 2015 07:15 PM
thatdumbass
Sep 28, 2014 07:37 PM
1QwIkEf
Jan 28, 2006 05:05 PM
1SlowSi
May 24, 2005 02:07 AM
h22acivichybrid
Jun 14, 2004 03:20 PM
