What size waste gate for my application?
Old Dec 22, 2010 | 10:29 PM
BoostinTEG's Avatar
Default What size waste gate for my application?
Im in the process of a turbo build and i wasn't sure what size wastegate would be best for my application.
Setup:
b16a
2.5" intercooler piping
Synapse Ramhorn manifold
57trim turbo
750cc injectors
ect ect..
im planning on pushing about 10-14psi
Im going with tial just wasn't sure what size to go with 38m,40mm,44mm ect
please give input
Thanks in advance
Old Dec 22, 2010 | 10:53 PM
rat city rex's Avatar
Default Re: What size waste gate for my application?
38 will be fine.
Old Dec 23, 2010 | 07:04 AM
BoostinTEG's Avatar
Alright, I just don't wanna drop money on a certain wastegate and then find out theres one that would work better in my setup.
CDecker0218's Avatar
get a TIAL 38mm. You will be good to go.
Old Dec 23, 2010 | 07:12 AM
siblues's Avatar
38 should be fine or get a 40mm that way if you decide to go bigger in the future you have some room to grow.
Old Dec 23, 2010 | 08:08 AM
boosted94gsr's Avatar
A 1.6l with a 57trim will do just fine with a 38mm wg. It's when u have a big turbo and are trying to run low boost that a bigger wg is needed.
Old Dec 26, 2010 | 02:18 PM
mechanix619's Avatar
What power level are you looking to make? That number will determine the psi you will need in order to make said power. A Tial 38mm will be good.
Old Dec 26, 2010 | 03:32 PM
nels00n's Avatar
^this
Old Dec 26, 2010 | 06:08 PM
BoostinTEG's Avatar
Between 300-350hp
Old Dec 26, 2010 | 08:51 PM
Between 300-350hp
A Tial 38mm would be perfect for that power range.
Old Jan 5, 2011 | 10:57 AM
MaxPow3r's Avatar
Bringing this back to the top...
What about 3.0L displacement, with a TO4E 60mm, 60 trim - .63A/R? Running between 7-9 psi.
I was originally thinking a 38mm, but wondering if it will not be enough to control that little boost... Problem is 38 to 44 is a decent jump in price...This is for 1/2 of my engine - as it's a 6L v8...so I still have to buy (2) wastegates.
Old Jan 5, 2011 | 11:14 AM
Mugencrxsir1's Avatar
38mm is perfect for your set up!
Tial or Synapse...
I'm running Synapse for both my BOV and Wastegate and I love both!
Old Jan 5, 2011 | 12:20 PM
TheShodan's Avatar
Moderator
You're one of the very few after the last year
Old Jan 5, 2011 | 01:08 PM
MaxPow3r's Avatar
What'd I miss about their wastegates?
lillthingz
Nov 18, 2008 08:51 AM
Speed Infliction
Jul 10, 2006 03:23 PM
97gsrki
Jan 21, 2006 09:22 PM
deftones0817
Feb 2, 2005 07:13 AM
Spoold_R
May 13, 2003 05:21 PM
