Are my pistons OK?
Old Dec 19, 2010 | 02:22 PM
white90crxhf's Avatar
Default Are my pistons OK?
my timing belt slipped, are these pistons ok? #4 had some shavings (i wiped them away before i took the picture... ) on it from me stupidly trying to start the thing a few times after it stopped starting.
why does one of the intakes look different?
can i swap the entire rocker-arm assembly & camshaft from the existing head to the head i got from the junkyard?
oil leaked from the head onto the pistons when i was removing it. Cylinders #2 & #3 look like they have alot of crap on them but it's just the reflection on the cylinder wall.
Old Dec 19, 2010 | 02:46 PM
QwkD16's Avatar
Default Re: Are my pistons OK?
If the belt jumped, the valves probably hit the pistons. You need to swap the valves, not the rocker arms.
Old Dec 19, 2010 | 03:34 PM
usdmftw's Avatar
they dont look bad, when you rotate the crank do cyl. wall 1&4 look fine? does it spin freely and smooth? and like posted above valve are prob the damaged part, but i imagine you know this since you mention getting a head froma junkyard(replacement head?)
Old Dec 19, 2010 | 03:40 PM
stackedhouse's Avatar
he wants to swap his cam and rocker arms onto a junkyard head.. not a cam and rockers from a junkyard head onto his... why would he swap damaged valves into a good head?
Old Dec 19, 2010 | 03:59 PM
QwkD16's Avatar
Misunderstood your post i guess. DONT reuse the head that hit the valves!!
Old Dec 19, 2010 | 05:40 PM
thanks for the answers, i wont reuse the bad head i promise
i imagine it's ok to reuse the timing belt since i didnt tighten the tensioner tight enough?
Old Dec 19, 2010 | 06:17 PM
vg_Ace's Avatar
the reason that one intake port looks different is possibly because the injector is going out. Was it idling rough when you had it running?
it might also be clogged and then it would not be spraying evenly. Also if your rings were going out and you had excess crankcase pressure your breather line might be working the wrong way and puking oil into your intake. Which is what mine did and it was quite dirty on the intake side.
Old Dec 20, 2010 | 02:47 AM
BiGZ's Avatar
In response to OP's orig ?,pistonz look fine-mere "love taps".Yes,can swap rocker assembly + cam onto JY head (might wanna replace the lil o-ring gaskets under rockers whilst @ it,keeps oil outta plug holez) New HG (sprayed w/ copper coat) ,and new timing belt if were mine...
H22CD7
May 2, 2007 11:26 AM
WREKONIZE V8 KLR
Mar 19, 2005 03:17 PM
THE *FOB* MOB
Aug 20, 2002 07:56 PM
Integra91LS
Mar 30, 2002 08:49 PM
