HKS Turbo Timer question...having trouble..
Here it is guys...I have an HKS Type-0 TT. I always set my TT for 3min. Sometimes, when I take out the key, sometimes it will only count down 2 sec. and shut off...and sometimes, it'll just shut off when I take the key out for some reason. Could it be wiring problems? I know its one of the easiest things to install, but maybe I just Mikey Moused it? Any help guys? Any suggestions?
Also, this turbo timer is so damn hard to figure out....
I hope someone can help...ThankS....
-Albert
-Albert
Do you have the parking brake on? Cause I know that if you don't the timer will not engauge. Also are you sure that you wired everything correctly? I would go back and double check.
Yea...I'm going to double check in a little bit. What I just found out was that after I take out the key, the TT will start counting down, but if theres just a vibration
(as if you shake the car on purpose) the car will shut off....I think it might be the wiring...any more suggestions?
blu_si.....THankS...
yeah...its a 240...SR20DET..I had a GReddy TT on my civic before. I regret selling it for the HKS...The only thing good about HKS to me is the voltage and the LCD screen colors..haha...anyways, yeah I'm going to check the wire out in bit..
Thanks
-Albert
Thanks
-Albert
Okay..I took a look at things and all wires are wired up correctly and securely...But when I shut off the car, the TT seems to shut off with it, and that's the problem. I dont understand because it was working before...how come its like this now? Could it be because of my alarm also? I didnt hook up the ignition wire so I can arm it while its counting down...something seems awfly strange...any help would greatly be appreciated...
-ThankS
-ThankS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-MiGiRL702 »</TD></TR><TR><TD CLASS="quote">Okay..I took a look at things and all wires are wired up correctly and securely...But when I shut off the car, the TT seems to shut off with it, and that's the problem. I dont understand because it was working before...how come its like this now? Could it be because of my alarm also? I didnt hook up the ignition wire so I can arm it while its counting down...something seems awfly strange...any help would greatly be appreciated...
-ThankS</TD></TR></TABLE>
bad ground? try grounding it in a different spot.
J.nguyen
Sep 30, 2006 04:27 PM
