can i use ls arp head studs for ls vtec?
Old Dec 16, 2010 | 07:41 PM
gs-r94coupe's Avatar
Default can i use ls arp head studs for ls vtec?
i have ls arp head studs in my ls and am going ls vtec do i have to buy diffrent studs for it or can i use my ls ones?
oh and im using a 96 gsr head
thanks
Old Dec 16, 2010 | 08:55 PM
Default Re: can i use ls arp head studs for ls vtec?
anyone?
Old Dec 16, 2010 | 09:29 PM
DDTECH's Avatar
use GSR head studs.
Old Dec 16, 2010 | 09:31 PM
Originally Posted by ALL M0T0R
use GSR head studs.
do i have to use them or can i use the ls ones i have?
Old Dec 16, 2010 | 09:32 PM
civic00sir.'s Avatar
yeah, like all motor said you should use the ones for GSR/ITR or the kit for ls/b20 with vtec head, but gsr ones are cheaper than the others...
Old Dec 16, 2010 | 09:34 PM
aight thanks ,
just out of curiosity whats the difference between them?
Old Dec 16, 2010 | 11:12 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
ls headstuds are the same except 2 of the headstuds are longer. the two that go in the middle of the ls head. if you need a set of gsr headstuds I have a set for sale. pm me if interested.
Old Dec 16, 2010 | 11:26 PM
speedtec11s's Avatar
You use the headstuds that work for the head your working with.
GSR head: GSR studs.
b16a/type r: use b16a/type r studs.
Golden eagle is what I recommend....pricey, but well work it.
check my site in my sig, I am a golden eagle dealer.
Old Dec 17, 2010 | 04:48 AM
kyden's Avatar
^^ type r studs are not the same as b16. you would use "gsr" ones on a type r motor.
Old Dec 17, 2010 | 10:46 AM
if you want to buy a arp GSR set, torqued once i could point to the person who have a great deal on them, lmk...
Old Dec 17, 2010 | 10:51 AM
Spawne32's Avatar
the studs are head specific, so pair them to whatever head your using, b16 head on whatever block, use b16 head studs, and so forth.
Old Dec 17, 2010 | 12:12 PM
pr0honda's Avatar
No.
The studs are BLOCK specific. the B16 is a shorter block, and uses shorter studs. The LS uses TWO longer studs in the center of a LS head, VS the B16/ GSR head. You need TWO center studs, the same length as the other 8 you have.
Old Dec 17, 2010 | 12:21 PM
Spawne32's Avatar
Originally Posted by pr0honda
No.
all b series blocks are the SAME with the exception of the bore, the difference between the blocks is the type of cylinder head they have, the LS uses two longer studs in the center of the LS head because the height of the head is higher in the center. This has NOTHING to do with the block.
Old Dec 17, 2010 | 12:24 PM
Spawne32's Avatar
Old Dec 17, 2010 | 12:27 PM
Spawne32's Avatar
heres a b16 head
kyden's Avatar
your first statement is wrong. b16 studs ARE shorter than b18/b16b. a b16 deck height IS shorter. b16 and b18 have the same bore, different stroke.
Old Dec 17, 2010 | 12:31 PM
Spawne32's Avatar
so basically what your saying is that the b16 head bolts wouldnt reach inside the head because of the lower deck height, fair enough. I had assumed that the deck height was not enough of a difference to cause the bolt to not properly fit, needless to say, this is correct for the b18c/b18b however.
Old Dec 17, 2010 | 12:45 PM
highroller54's Avatar
LOL! you better buy a timesert kit if you believe this.
Old Dec 17, 2010 | 12:50 PM
Spawne32's Avatar
not even sure how you could say this when you can clearly see the visible difference between the height of the bolts in the heads themselves.
Old Dec 17, 2010 | 12:59 PM
Spawne32's Avatar
wait a second, b18c and b16b arp studs are exactly the same part #
Old Dec 17, 2010 | 01:37 PM
pr0honda's Avatar
True, but different than B16A. That is why you need to know what block you have to order studs. And yes you can use your B16A rods in your B16B. LOL
Old Dec 17, 2010 | 01:45 PM
Spawne32's Avatar
fair enough lol
Old Dec 17, 2010 | 03:03 PM
Loved
Community Favorite
ya b16b is same deck height as a ls/ gsr block. b16a is like .25" shorter if I remember right.
Old Dec 17, 2010 | 09:27 PM
so could i use my ls arp studs and use the two longer ones oem gsr studs?
gs-r94coupe
Jan 1, 2011 07:55 PM
almostjdmeg
Jan 3, 2009 07:41 AM
aemintgsr
Apr 7, 2007 11:52 AM
See Are X
Oct 10, 2005 07:13 AM
1SlowSi
Apr 15, 2005 01:58 PM
