can i use ls arp head studs for ls vtec?
i have ls arp head studs in my ls and am going ls vtec do i have to buy diffrent studs for it or can i use my ls ones?
oh and im using a 96 gsr head
thanks
thanks
Re: can i use ls arp head studs for ls vtec?
yeah, like all motor said you should use the ones for GSR/ITR or the kit for ls/b20 with vtec head, but gsr ones are cheaper than the others...
ls headstuds are the same except 2 of the headstuds are longer. the two that go in the middle of the ls head. if you need a set of gsr headstuds I have a set for sale. pm me if interested.
You use the headstuds that work for the head your working with.
GSR head: GSR studs.
b16a/type r: use b16a/type r studs.
Golden eagle is what I recommend....pricey, but well work it.
check my site in my sig, I am a golden eagle dealer.
The studs are BLOCK specific. the B16 is a shorter block, and uses shorter studs. The LS uses TWO longer studs in the center of a LS head, VS the B16/ GSR head. You need TWO center studs, the same length as the other 8 you have.
all b series blocks are the SAME with the exception of the bore, the difference between the blocks is the type of cylinder head they have, the LS uses two longer studs in the center of the LS head because the height of the head is higher in the center. This has NOTHING to do with the block.
so basically what your saying is that the b16 head bolts wouldnt reach inside the head because of the lower deck height, fair enough. I had assumed that the deck height was not enough of a difference to cause the bolt to not properly fit, needless to say, this is correct for the b18c/b18b however.
almostjdmeg
01-03-2009 07:41 AM
