Transmission & Drivetrain Gearboxes, Differentials, Clutches
Clutch/Flywheel or transmission problem?
Old Dec 12, 2010 | 10:38 AM
bigluelok's Avatar
Default Clutch/Flywheel or transmission problem?
car- 88 civic wagon
engine- d15z1
transmission - 89 ef tranny
ok so a while ago My wagon locked up while driving in the middle of the intersection.
then I pushed the clutch and was able to limp it over to the side of the rode.
now when i engage the clutch the car rolls fine. when i turn the car on if i let go of the clutch it kills the car. would that be a transmission problem or clutch problem?
thanks for all the help
if you need to know anything i will do my best to answer your questions.
Old Dec 12, 2010 | 10:50 AM
efjones9's Avatar
Default Re: Clutch/Flywheel or transmission problem?
is did u adjust the clutch cable too much my fellow dso bro lol
Old Dec 12, 2010 | 10:56 AM
bigluelok's Avatar
yeah i adjusted it but its not tight.
Old Dec 12, 2010 | 10:59 AM
efjones9's Avatar
is it hard to go into the gears?
my friend had a similar problem. we jus removed the trans re-aligned the clutch and re tightend the pp with the clutch tool in and was fine wen we started it
Old Dec 12, 2010 | 11:00 AM
efjones9's Avatar
also che to see the axels are installed all the way
Old Dec 12, 2010 | 05:00 PM
bigluelok's Avatar
axels are in all the way it may just be the clutch we will find out this weekend.
TigerLy
Jul 16, 2008 01:59 PM
Bngo731
Feb 23, 2006 12:02 AM
_Endless_
May 21, 2004 11:57 PM
abeaujuin
Jan 9, 2004 04:43 AM
EF8_SiR
20
Oct 22, 2003 10:41 PM
