clutch problem
Old Feb 7, 2006 | 06:10 PM
Bngo731's Avatar
Default clutch problem
lately my clutch has been shakey when i start it up and when u try to put it in gear and take off the whole car shakes with the clutch but the clutch would stop shaking after like 2 minutes. what could be the problem?
Modified by Bngo731 at 8:17 AM 2/8/2006
Old Feb 8, 2006 | 04:17 AM
Bngo731's Avatar
Default Re: clutch problem (Bngo731)
someone please help
Old Feb 8, 2006 | 01:07 PM
jmcool's Avatar
maybe your throw out bearing. but i am not really sure
Old Feb 22, 2006 | 09:35 PM
anothA civC's Avatar
Default Re: clutch problem (jmcool)
bump, I am having the same problem.
Old Feb 23, 2006 | 12:02 AM
methanemotorworks's Avatar
what kind of clutch is it...stock...after market..?...cause mine does it to but only because its a what they call a stage 5 clutch...which is only a six puck...unsprug clutch disc with a heavy duty pressure plate...no spring in the disc means no compensation for clutch and flywheel mating...so when it grabs and you try to even it up...it gets shakey...hey my whole front ends jumps up and down...if its a stock clutch then please be more thorough about your explaination...
o'malley_808
Nov 10, 2005 07:51 PM
Curtisbeef
Sep 15, 2004 03:00 PM
Nextelbuddy
Mar 5, 2004 06:06 PM
Austin
Mar 30, 2002 04:50 AM
