rebuild my b20vtec
Old Dec 10, 2010 | 09:11 PM
egycasper16's Avatar
Default rebuild my b20vtec
hi
i finished my b20vtec and it was great but something happen wrong :-( the engine died
anyway i have to rebuild it by porting the stock sleeves to be 85mm
is that ok with block guerd and the cr will be 12.1:1 with s2pro2?
i cant resleeve it also.
is RS ITR pistons is ok to work with H-beam eagle rods and eagle crank?
thanks
Old Dec 11, 2010 | 04:40 AM
Natural Aspirations's Avatar
Default Re: rebuild my b20vtec
Originally Posted by egycasper16
hi
anyway i have to rebuild it by porting the stock slaves to be 85mm
i cant reslave it also.
thanks
You spent too much money on an engine and didn't spend enough time learning what you were doing.
Old Dec 11, 2010 | 11:02 AM
DDTECH's Avatar
Or passing 3rd grade english.. sorry, i gotta clown someone. You're the 4th thread i've read in 5 mins where someone can't type correctly, its so hard to help over the internet without proper grammer.
Old Dec 11, 2010 | 02:28 PM
hey man's Avatar
Icon2 Re: rebuild my b20vtec
agree ^
Old Dec 11, 2010 | 08:43 PM
fv8s's Avatar
There are slaves in your engine? LET THEM GO!!
Old Dec 11, 2010 | 10:24 PM
thanks for everyone for help,,its hard to type when you write from mobile,anyway about my engine it could happen to anyone as my damage because of an ignetion
i built my engine by my self as i spent tones of time over the researching and many ppl helped me alot
you can see my engine cluster from YouTube on s2pro2 .
Eg9 4 door civic with sunroof ,,
thanks for helping and supporting for everyone.
Old Dec 12, 2010 | 09:34 AM
i am asking if 85mm is working with b20 sleeves with 12 cr or not
Old Dec 12, 2010 | 10:08 AM
Professor15's Avatar
It's hard to believe but there are other languages besides english. So it goes along way to try n be helpful instead of jump the gun.
And to the op, if you can swing it. Just sleeve the block for piece of mind
Old Dec 12, 2010 | 01:26 PM
fv8s's Avatar
Yes 85mm with that compression ratio will work. There is a lot of information out there on this topic so search it.
Stevenpace
Jun 23, 2013 09:10 AM
ITRnorway
Aug 28, 2006 02:00 AM
B18C GSR CIVIC
Oct 23, 2003 07:21 PM
Trajic
Sep 5, 2001 08:28 AM
