92 hatch - sparks near starter and now it won't crank
Old Nov 29, 2010 | 06:22 AM
89 ed6 FTW!'s Avatar
Default 92 hatch - sparks near starter and now it won't crank
so i recently changed clutches on my 92 hatch and i put the trans back on then the starter and when i put everything on right and hooked the negative cable to the battery i heard a spark down by the starter. i didnt think anything would be wrong so i tried to start it and nothing happend. all u could hear was my pump engaging. could someone help me? also wheres the starter relays or anything fuse wise for the starter
Old Nov 29, 2010 | 09:37 AM
Former User's Avatar
Default Re: 92 hatch - sparks near starter and now it won't crank
Is there voltage to body ground at both starter wires? Voltage at the smaller solenoid wire must be checked with key in ON(III).
Is the G3 transmission ground wire connected, clean, and tight?
Old Nov 29, 2010 | 11:04 AM
whats the G3 ground?? all grounds are clean and tight. and yes theres voltage to all them like u said. i took the starter apart and there was a hole melted into a long magnet thing that pulled out
Old Nov 29, 2010 | 11:07 AM
G3 is just the transmission ground located on top of the transmission.
That's the problem.
Make sure to correctly connect the starter wires to the replacement starter.
GoBrowns
Oct 3, 2013 02:56 AM
wheelerboy12
Sep 22, 2013 08:42 AM
ev94eg
12
Jul 31, 2012 06:31 AM
BobbyRodriguez
Nov 16, 2011 05:15 AM
GoodEyeSniper
17
Sep 8, 2006 11:31 PM
