Transmission & Drivetrain Gearboxes, Differentials, Clutches
BIG PROBLEM! with newly rebuilt trans.
Old Nov 24, 2010 | 05:56 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default BIG PROBLEM! with newly rebuilt trans.
Hey guys, I put a new Mfactory diff in my b16a2 trans, as well as new sleeves, syncs, seals.. The whole nine yards.
We get the trans in, everything all bolted up and I push the clutch to start the car, I left off the clutch (IN NEUTRAL) and it dies. I start it again, go in and out of a gear to make sure I'm in neutral and same thing, something is loading the trans but it won't move forward or backwards. I slide the shifter into first and left off the clutch and the car will move forward.
So what's the deal? Also, It's very difficult to go into any gear with the motor on/off clutch in and out. 5-reverse side is almost impossible to get the shifter there unless you wiggle the shifter a ton.
So what'd we mess up on rebuilding the trans?
Old Nov 25, 2010 | 08:07 AM
Default Re: BIG PROBLEM! with newly rebuilt trans.
25 views and no suggestions?. FUUUUUUUUUUUU
Old Nov 25, 2010 | 01:16 PM
stevenDAtegra's Avatar
Did the mainshaft spin once the transmission was put back together? Did you check the clearances for the diff?
I'm not too sure if too tight of a clearance would seize it so badly that the trans wouldn't move but it could be a possibility? Did yo replace the mainshaft shims and in the right order?
Old Nov 25, 2010 | 05:15 PM
Runnerdown's Avatar
If the parts are improperly installed it could be locked into gear.
Old Nov 25, 2010 | 06:12 PM
Aquafina's Avatar
Could be a lot of issues. Start with the clutch system first (CMC and CSC, clutch itself) then go back into the trans if all is good there.
Old Nov 25, 2010 | 06:46 PM
raffaelli's Avatar
One of those rings that hold a syncro in place could be broken or out of place?
Old Nov 25, 2010 | 06:49 PM
JohnnyBuilt's Avatar
same thing happen to me, came to find out it was the clutch release bearing... hope that helps
Old Nov 26, 2010 | 05:12 PM
it was the shift selector mechanism. Sort of hard to explain but it's what moves when the shift linkage wiggles back and forth.
*Whew
Old Nov 26, 2010 | 05:31 PM
Aquafina's Avatar
Bent and/or cracked or not aligned properly?
Old Nov 26, 2010 | 09:43 PM
first, the builder hammered the case on which cracked the case. we got the piece welded back on where the rod of the selector slides in. it ended up being bent towards the bottom of the case about a 1/8-1/4 inch which made it difficult to select gears and no neutral..
put a new selector in and worked like a champ!
Old Nov 27, 2010 | 09:01 AM
Aquafina's Avatar
Classic lol.
In the future use a professional for the install.
Old Nov 28, 2010 | 08:27 PM
ehhh, there's a first for every mistake. trans works perfect now
ohsnapzafingcu
10
Dec 13, 2010 06:44 AM
Will_H
Sep 4, 2008 08:32 PM
RTW DC2R
Jul 25, 2007 07:30 AM
Lo-Buck EF
Apr 28, 2003 06:56 PM
r4adkshn1
Nov 23, 2002 06:22 AM
