can a brake booster be painted or powder coated?
Old Nov 22, 2010 | 10:37 AM
Charlie Moua's Avatar
Default can a brake booster be painted or powder coated?
So I'm detailing my bay and wanted to know what options I had for coloring my brake booster.
Ideally i would like it to get powder coated but i'm not sure if that's safe or not since I don't know what the internals of the booster is and if it would be okay in an oven.
if i can't do that I could just have paint shop paint it black with clear coat.
Old Nov 22, 2010 | 05:13 PM
JDMJoey's Avatar
Default Re: can a brake booster be painted or powder coated?
good question.....sorry i cant help
Old Nov 22, 2010 | 05:18 PM
Hawkze_2.3's Avatar
Just paint it...I can't imagine why you would need powder coating for that.
Old Nov 22, 2010 | 06:26 PM
Chef Andre's Avatar
HT's TOP CHEF
Not sure if it's true but I read somewhere that the heat from powdercoating the booster could mess up the diaphram inside. Didn't make any sense to me cause the engine compartment gets hot anyway.
I just painted mine and it came out perfect.
Old Nov 22, 2010 | 06:27 PM
well the engine bay get's hot but only to maybe 100-150f.... when you powdercoat.... it's in an oven much hotter that than.
i'll look into painting it.
I just wanted to see if anyone else has been able to poweder coat the BB with out issues to the internal diaphram
Charlie
Old Nov 22, 2010 | 07:28 PM
sc34dc4's Avatar
Powder coated parts go into an oven at 400 degrees for around a half hour. Just had my valve cover done and was curious about the process so I asked a few questions. Just base/clear it. It's metal just like the fenders. No problems if it's prepped well.
Old Nov 23, 2010 | 05:48 AM
jasoncrashtech's Avatar
i painted my valve cover with ppg and i have no problems, even driving around all summer on 8lbs. of boost. the paint has not failed. (sig)
i think painting your brake booster wouldn't be a problem with good prep and paint.
Old Nov 23, 2010 | 07:14 AM
Linh.'s Avatar
The diaphram is rubber so no but they do have low heat powder coating available I believe.
stevescivic
Apr 18, 2008 04:38 AM
amej8
Jan 13, 2007 07:46 PM
jfastman
May 18, 2004 03:17 PM
b16ej1lsd
Sep 8, 2003 01:23 AM
AK94GSR
Jun 22, 2001 11:58 AM
