Transmission & Drivetrain Gearboxes, Differentials, Clutches
Hybrid Tranny Question
Old Nov 18, 2010 | 08:53 PM
bmxkills's Avatar
Default Hybrid Tranny Question
Well I have a GSR tranny that I'd like to basically turn into a '98 Spec Type-R tranny. I want a 2.105 second gear, and a 1.458 third gear, along with the 4.7 Final Drive and OEM LSD. I would like to know what's the best way to go about this, and if the B16 second and third gears are compatable. I know I'll have to us a '98 Spec ITR/Aftermarket countershaft, but that's it. I'm transmission retarded.
Can I use my GSR 1st, 4th, and fifth on the ITR/Aftermarket countershaft?
Are the B16 2nd and 3rd gears able to work on the ITR/Aftermarket countershaft?
Any input would help, thanks.
Old Nov 19, 2010 | 05:29 AM
unusual71's Avatar
Default Re: Hybrid Tranny Question
i believe you need to keep the 3-4 as a pair ie. use either the b16 ones or the gsr ones. Not sure specifically though maybe b16 and gsr are interchangeable but i know some are not, due to the slider/hub assembly.
all b series first gears have the same ratio
to use b16 second you will need the b16 main shaft. the counter shaft should work with any gears, the important thing is to keep your countershaft and final drive as a matched pair.
Old Nov 19, 2010 | 09:13 AM
bmxkills's Avatar
Well if 3-4 is a pair, I'd have to buy '98 Spec ITR, correct? And to put a 4.7 FD I'd need the '98 Spec ITR or aftermarket countershaft, but did not know anything about changing the mainshaft... Hmmm. Thanks for the input. Anyone else?
Old Nov 19, 2010 | 12:18 PM
Aquafina's Avatar
Buy a 98+ JDM ITR trans or a USDM ITR trans and add the 4.7 in, or a B16 trans and add the LSD and 4.7 in.
To get what you want you need:
B16A2/B18C5 mainshaft
B16A2/B18C5 countershaft 2nd gear
B18C 98+ countershaft 1st gear, collar, needle bearings
B18C 98+ ring gear
B18C LSD
B16A2/B18C5 mainshaft and countershaft 3rd gear
Old Nov 19, 2010 | 06:01 PM
bmxkills's Avatar
Thankyou, I was waiting for your input! That's what I want/didn't wanna hear :/. Is there anything I could do to shorten up second gear on my GSR tranny, and still possibly do an LSD and FD?
Old Nov 20, 2010 | 08:27 AM
Aquafina's Avatar
Only way to shorten second is a shorter FD or actually changing out 2nd to B16A2/ITR.
I have a C5 trans here, all that would be needed for your setup is an MFactory or OEM FD (if you don't want the stock 4.40).
Old Nov 20, 2010 | 09:38 AM
bmxkills's Avatar
Ithought the B16A2/ITR second wouldn't work unless I swapped shafts? Lol, I'm a tranny newb. How much, just curious? Thanks for the help!
Old Nov 20, 2010 | 05:45 PM
Aquafina's Avatar
Correct. When I say 2nd gear, I mean the mainshaft and countershaft 1/2.
Old Nov 21, 2010 | 08:56 AM
bmxkills's Avatar
Haha, damn. Maybe I'll reevaluate this Thanks for the input!
eg4life1202
Nov 13, 2006 07:42 PM
swaytec360
39
Jul 15, 2005 06:02 PM
swaytec360
Jul 12, 2005 08:11 PM
Ransom
Mar 15, 2004 09:19 PM
philipwight
Jan 27, 2004 06:22 PM
