D16y8 head swap question
I have a 1998 civic 2dr ex 1.6 D16y8 sohc vtec that I am replacing the head on. The casting # on my original head is P2J-5. It has the lost motion assy. on top. I purchased a remanufactured head for a D16y8 but it has a casting # P2J-1. It came with roller rockers and no lost motion assy. The heads look the same except for the valve train. Will I have any problems with this swap?
People miss this every time. The Y8 does not have roller rockers. No LMA's and rollers = Y5
It's been debated how the Y5 head would work with the Y8 ecu because of how vtec and vtec-e differ. You would also have to deal with the egr passages on the Y5 that your Y8 doesn't have.
In short you would much better off getting the correct head. I don't have much experience with the Y5 so maybe someone who does can chime in. Will it bolt to your block? Yes. Will your intake manifold bolt to the head? I think it will bolt up but I think the egr pasages on the Y5 head is where the water pasage is on the Y8. To get around this I beleive you would need to use the Y5 intake mani. Then you get to vtec vs. vtec-e. With vtec on a SOHC you run on 16 valves and when it engages the 8 intake valves operate off the high lift cam lobes.Vtec-e runs in a 12 valve mode (8 exhaust + 4 intake) which has a very low lift on the intake side for economy. When vtec-e engages (@ 2800-3000 rpm I beleive) it locks all 8 intake valves together so it now runs on all 16 valves with a slightly increased lift.
Okay, so what I've gathered here is that the manufactured head you got for your engine is infact a Y5 head.
If you bought this from a legitimate shop, I'd bitch because they gave you the wrong part.
Thanks for all the great info. I talked to the shop and explained the difference between the vtec and vtec-e. They are sending me the correct head. Without this forum I would have not questioned the head and would be scratching my head wondering why the car is running so bad!
shawnperolis
17
Aug 30, 2013 11:19 AM
