whats a good lsd brand for a b16a1
Well you have a few choices....
Quaife makes LSD Diffs for B-series trannys, and are one of the best around. They run from 700-1400 bucks depending on model.
Phatom Grip -aka bunny grip is a lsd device, that goes in your stock diff and locks it up. Some road racers like these, but personally I have used one and think it kinda blows for drag racing, yes its better than nothing.. But for 250 bucks a small peice of metal really isnt worth it.
Kaaz Makes LSD's for B-series trannys as well, but I dont know much about them, I belive they are strictly JDM..
Or you could get a Factory LSD Diff, offered in some YS1 and Y1 trannys.
Jeff Frank
Jeff Frank
the transmission that you have dictates what LSD's are compatible. i believe that with an S1, the factory LSD will not work because of different gearsets and bearing mounts. it may be possible to put in a YS1 (stock LSD tranny) gearset and LSD, this should cost more than a Quaife. my reccomendation would be to look into the ATS gearset and diff, (if they make a diff??) this will shorten your gearing significantly, drastically improving acceleration, and use stronger synchro's. JDM_DOHC_SIR posted some very good information on this subject a few months ago. SEARCH!!!
guys, if u wanna know, every LSD has diferent intended purposes. the "phantom grip" will break easily, dont use that. go into a forum that actually knows about aftermarket LSD (ITR/roadracing) and ask them, im sure they ahve ALOT more useful info on LSD's than other ppl
[Modified by MnC CRX, 8:47 PM 9/22/2002]
