quick cosmetic question about welds
Old Nov 14, 2010 | 07:42 PM
sc34dc4's Avatar
Default quick cosmetic question about welds
Alright so today I spent a bunch of time grinding down the welds on my ic pipe and then used a cup brush to smooth it out as best I could. So now that I've done this what else could I do to completely smooth it out? Since the pipe doesn't see any type of heat would it be alright to use a light coat of filler to smooth it out? I was also thinking maybe 2-3 coats of a self etching primer before a few coats of paint. Thanks in advance H-T
Old Nov 15, 2010 | 06:20 AM
sc34dc4's Avatar
Default Re: quick cosmetic question about welds
Any suggestions?
Old Nov 15, 2010 | 07:00 AM
unusual71's Avatar
yeah filler will work. aluminum is tricky though if thats what your working with, not sure if they make filler that is specific for aluminum, regular stuff works but its a little tricky.
Old Nov 15, 2010 | 07:22 AM
sc34dc4's Avatar
It's just a stainless charge pipe. I planned on painting it black and I know how bad that shows imperfections.
Old Nov 15, 2010 | 08:01 AM
4cefed's Avatar
You could use plastic filler. Just sand the whole thing good so you get some bite and fill what you need to fill, block it smooth and prime.
Old Nov 16, 2010 | 07:09 AM
tigmaster13's Avatar
you should fill in the undercut with more weld, then grind smooth and blend in with a mounted flap wheel, and dont paint it...polish it...painting takes away the anti corrosive capabilities of stainless....to bad we dont know eachother...id love to build that
Old Nov 16, 2010 | 07:46 AM
sc34dc4's Avatar
Originally Posted by tigmaster13
You should fill in the undercut with more weld, then grind smooth and blend in with a mounted flap wheel, and don't paint it...polish it...painting takes away the anti corrosive capabilities of stainless. To bad we don't know each other. I'd love to build that.
Where I grinded down the welds was fine. It was the area 2" before and after it from where the grinder was hitting. I spent a few hours on it last night and it's almost finished now. I did one coat of bondo and one of icing and hand sanded it all from 220-400. I have a few pin holes that I will fill in tonight and it should be good to go.
Old Nov 16, 2010 | 02:32 PM
welfarepc's Avatar
filler will work just fine.
i used filler on a valve cover a long while back and its still mint.
Old Nov 16, 2010 | 09:12 PM
sc34dc4's Avatar
Well it's not perfect but it's 100% better then what it was before. Finished up with the filler tonight and then sanded it down. 3 coats of high build primer and wet sanded the last 1 and hit it up with some alumi blast. Not bad for 2 evenings in the basement and about $20.
Don't mind the 1st pic it's from when I was boosting the car like a year ago.
Started out looking like this...
Ended up like this...
Old Nov 16, 2010 | 11:54 PM
Westrock2000's Avatar
Yep looks good.....though I saw the first one and thought that was the finished product ^_^
That was MIG weld?
Old Nov 17, 2010 | 07:05 AM
sc34dc4's Avatar
That was MIG weld?
Yeah I had a friend do it for me since I can't weld.
AM_H2B
Welding / Fabrication
Feb 6, 2015 01:04 PM
EdsGTI
May 24, 2007 10:21 PM
redboost10
Aug 27, 2006 01:02 PM
number7s
Feb 8, 2005 06:52 PM
notstock93
Apr 17, 2004 01:39 PM
