Honda CR-V & Element 2WD & 4WD Element & CR-V
nameplate tire PSI too low?
Old Nov 14, 2010 | 08:49 AM
ginahoy's Avatar
10 Year Member
Default nameplate tire PSI too low?
My wife's 2006 CRV has 30k miles (7.5k/yr). The OEM Dunlops are all wearing thin on inside and outside edges. They now need to be replaced. All four have similar wear so alignment wasn't an issue.
Unfortunately, I didn't notice until it was too late. The mechanic who maintains the vehicle said he always verifies inflation to nameplate on door jamb, which is 29/29. He checks inflation after completing an oil change or other service, so the tires are cold. I'm a bit miffed that he didn't notice the wear pattern much earlier. We probably would have gotten another year on these tires.
Has anyone else experienced edge wear at 29/29? I will increase pressure on the next set. Would 32/32 be appropriate?
Old Nov 14, 2010 | 11:50 AM
MonkeyMagic's Avatar
Default Re: nameplate tire PSI too low?
i can say that at 32 32 i've been getting good, even wear.
PatrickGSR94
Suspension & Brakes
28
Jul 6, 2007 05:37 PM
phoshizzle88
Oct 14, 2005 06:53 PM
dgrave
Dec 19, 2004 09:26 PM
Dancing is Forbidden
Aug 17, 2003 05:42 AM
ahunt01
Jul 17, 2003 04:22 PM
