How to change a rad in civic 90 h dx
Old Nov 12, 2010 | 06:16 PM
colonel2's Avatar
Default How to change a rad in civic 90 h dx
this is my first time doing this, I found a leak between the plastic and the aluminum core, I need to watch a video o anyway to take the lower hose. My friend is selling a new rad for the 90 1.6, Is ok to use it on my 1.5 civic?
thanks
Old Nov 12, 2010 | 07:15 PM
Eclectia's Avatar
Default Re: How to change a rad in civic 90 h dx
The 1.6 radiator should work fine. this is a very simple task, start by draining all your coolant, then simply undo the hoses and brackets, and swap radiators. Refill your cooling system and make sure you bleed the system properly to make sure there is no air trapped in the coolant.
Old Nov 12, 2010 | 07:47 PM
colonel2's Avatar
I forgot to tell you my honda is automatic, the new radiator must have those holes for the tranny
Old Nov 12, 2010 | 09:01 PM
miguey310's Avatar
huh ?
Old Nov 12, 2010 | 11:31 PM
ED94LIFE's Avatar
I'm guessing the "holes" are to cool the transmission fluid?
Old Nov 13, 2010 | 05:42 AM
colonel2's Avatar
yes, I trying to get familiar with the civic 1.5 and 1.6, my civic got those holes for the transmission cooling..
Old Nov 13, 2010 | 09:06 AM
Deetz's Avatar
Crazy Honda Guy
The auto has 2 small lines that come out of the bottom for tranny cooling as mentioned, they are no big deal, just a couple extra hoses to swap over. Many oem style aftermarket rads have the lines at the bottom to fit all applications
Old Nov 13, 2010 | 09:11 AM
miguey310's Avatar
here's a civic radiator , http://cgi.ebay.com/Japspeed-Civic-C...item43a2b0a0a1
now what hole are you talkin about ?
Old Nov 13, 2010 | 12:58 PM
colonel2's Avatar
I got this one
http://www.autopartswarehouse.com/po...dhcnJhbnR5Lg==
Old Nov 13, 2010 | 03:13 PM
miguey310's Avatar
it a regular rad
Old Nov 13, 2010 | 03:15 PM
alphalanos's Avatar
some replacement ones dont have the trans cooler holes. I accidentally ordered one, so I had to get a separate trans cooler and hook it up.
kyleeann
Nov 4, 2014 05:03 PM
thedon360
Jun 12, 2013 05:20 PM
Mike1984
16
Feb 4, 2012 01:48 AM
Briang3a3
Jan 17, 2008 10:57 AM
udm_motorsport
May 12, 2003 10:50 AM
