96 Civic coupe - Parking lights fuse keeps blowing
Old Nov 11, 2010 | 03:35 PM
jdm_addict813's Avatar
Default 96 Civic coupe - Parking lights fuse keeps blowing
96 civic coupe b series
Hey ht i have a problem with my fuse shorting out for my parking lights, corner light, and license plate fuse for some reason as soon as i turn on the switch the fuse goes out. I dont know whats causing this but i really need it fixed so i can drive at night or else my tail lights wont work so someone please help it would be appreciated thanks. Also more info its supposed to be a 7.5 fuse and ive put a 20 fuse when i tried it if i need a 7.5 then ill go buy one but idk if thats whats causing it or not.
Old Nov 11, 2010 | 03:55 PM
Default Re: Fuse keeps shorting out
anyone??
Old Nov 11, 2010 | 04:13 PM
Former User's Avatar
Don't install a higher amp fuse. It's a fire hazard and may lead to expensive wire damage.
If you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please familiarize yourself with the stickies at the top.
Old Nov 11, 2010 | 04:26 PM
so that can be the problem? and i have a 96 civic coupe
Old Nov 11, 2010 | 04:28 PM
No but it can cause additional damage.
Did you do any wiring work lately?
7.5A dash fuse 32 is blowing, right?
Old Nov 11, 2010 | 04:47 PM
no the only thing ive done is connect a aftermarket radio and im starting to think its shorting something out in there i will go take a look now and see if anything is touching
Old Nov 11, 2010 | 05:19 PM
Fuse 32?
If you unplug the connector to the taillights in the rear, does the fuse stop blowing?
Old Nov 11, 2010 | 05:49 PM
HondaPartsHero's Avatar
Technical Hero
What make and model is it (hatch , coupe, sedan)
Old Nov 13, 2010 | 12:10 AM
coupe
Old Jun 13, 2011 | 02:10 PM
hialeahzbg's Avatar
Default Re: 96 Civic coupe - Parking lights fuse keeps blowing
im having the same problem on my 2000 civic coupe... only thing i did was add another ground to the radio harness because the radio would turn off with the brakes...
stupidasso15
16
Mar 15, 2012 09:07 PM
crazydrew
Oct 23, 2007 12:33 PM
chelude
Honda Civic (2006 - 2015)
Oct 13, 2007 01:38 PM
skyvang2
May 28, 2007 03:21 PM
thepapis610
Mar 7, 2006 09:39 AM
