Early rev limit
Alright guys I'm trying to help a buddy fix his car because it revlimits about 1500 rpms too early. I've searched and searched and came up with nothing that has fixed the problem. It's a pretty basic p30 pistons lsvtec on a chipped p28. So far we have changed out the ecu, dizzy, wires, plugs, iat sensor, speed sensor, cluster, injectors, fpr and nothin has changed. I'm up for any ideas.
Its really unlikely for an oem cluster to read 1500rpm low. My jdm itr cluster reads about 300rpm high, which I dont mind. Your problem is probably in the chip. Thats about all thats left.
I've used 3 different ecus, 2 chipped with 2 different redlines and one stock p30 and they it redlines about 1500 before each one is suppose to so that's not the problem.
No cels, already thought of the tach that's why I changed the cluster out. And that would be great all motor but I don't have a chip burner.
The transmission/ vss will not affect rev limit. The ECU only uses the VSS input to calculate fuel compensation for a given gear.
It could be the tune or the tranny i have a d16 tranny with d15b and before my tune it would rev only to 5 then i advanced the timing and fuel and it revs to 7 but the noise it made at redline was sharp and sounded like cracking and knock not like a rev limit
jdmvtecej2
Oct 27, 2008 04:46 PM
