what trans should i use on my gsr turbo
Old Nov 10, 2010 | 08:53 PM
ja20_eg's Avatar
Default what trans should i use on my gsr turbo
lmk know what the best tran to use on my gsr swap that soon to be turbo..give me some info..pros and con on the trans...thanks
Old Nov 10, 2010 | 09:28 PM
jdmchinoCDN's Avatar
Default Re: what trans should i use on my gsr turbo
dog box
Old Nov 11, 2010 | 04:31 AM
blackeg's Avatar
get an lsd and use the gsr trans. there are a decent amount of people out there now using stock gsr trannys with an lsd making sub 10 second passes
Old Nov 11, 2010 | 11:12 AM
AlexDphoto's Avatar
GSR with LSD
shorter than an LS tranny, so you will accelerate faster, but not as short as a b16, will give you decent trap speeds.
Few guys in my area running GSR transmissions with LS final drives to increase their trap speed at the strip.
Old Nov 11, 2010 | 12:51 PM
umair's Avatar
id go with the gsr also. mine went out on me this year so i put an ls trans on my car and it felt slower. the gearing kinda sucks too because if i don't rev it out it falls out of boost between shifts.
the gsr is prefect, not too long and not too short.
Old Nov 11, 2010 | 12:59 PM
Silva Bullit DC4's Avatar
Originally Posted by AlexDphoto
GSR with LSD
I agree with Alex, & no cons I can point out, the GSR tranny is a good median point between the B16 & LS, and X2 on the LS final drive. Some will even add an LS 5th for better 5th gear highway use.
Your desired redline & car purpose will play a role as well, OP.
Old Nov 11, 2010 | 08:44 PM
ja20_eg's Avatar
how bout a itr trans lsd...would the gsr still be best...
Old Nov 11, 2010 | 09:00 PM
CaliforniaDad's Avatar
No-Traction = Fun
Man-O-Man ,,,,,,, I swear every day I drive to work in my car I always and i mean always catch myself reaching down and trying to shift into another gear. My GSR just feels like it needs a taller 5th gear or a 6th gear. so.....Is it pretty strait forward to install the LS 5th gear in the GS-R transmission?
Old Nov 11, 2010 | 09:31 PM
DDTECH's Avatar
ALOT of people do a GSR with lsd and ls 5th gear..
or they go b16 with a b16 1/2nd gears gsr 3/4 and ls 5th with a b16 FD
I've tuned probably 3 cars in this month alone that have done some type of b16/gsr/ls hybrid tranny setup... all cars making sub 400whp levels.
Old Nov 11, 2010 | 10:29 PM
jdm inc's Avatar
x2
i went 10.02@149 on a stock gsr lsd tranny.
Old Nov 11, 2010 | 11:22 PM
slowtegkauai's Avatar
What you guys think about this...
A LS trans with a Mfactory 1st 3.070 gear and a Mfactory 4.785 final drive with their clutch type LSD?
.1st gear is taller than stock. Which helps bring the speed back up in first since the final drive lowers speed on all gears.
.wont have to shift into 5th gear in the 1/4 mile.. max speed at 8500RPM on 24.5'' slicks= 138-140mph.
Old Nov 12, 2010 | 11:26 AM
skuded's Avatar
I love my gsr trans, however an ls 5th gear would be great, at 80mph im turning 4k rpms, but i just look at it like it keeps me from speeding, 60 is a bit under 3k and i just stay there
Old Nov 12, 2010 | 12:23 PM
AlexDphoto's Avatar
ITR tranny is like a B16 with LSD, wouldnt be bad at all, just highway cruising your RPM's would be up there, so gas mileage would be affected, not that gas mileage should be a priority for anyone boosting though
Old Nov 12, 2010 | 12:53 PM
jetspeedz's Avatar
if it's a daily driver i suggest Ls 5th, im in the process of swapping to it now. Also don't forget LSD. MFactory LSD here.
Old Nov 12, 2010 | 04:29 PM
No-Traction = Fun
Let me know how that goes, I wanna do the same thing in my GSR trans
Old Nov 12, 2010 | 04:57 PM
jetspeedz's Avatar
Will do, but i have some bad news for anyone who wants the 5th gear countershaft, they are on back order so they are ordering them from japan and it could be weeks to months. Luckily i got the last one and it should be here in a week.
Old Nov 12, 2010 | 05:40 PM
No-Traction = Fun
what did that run you, if you dont mind me asking?
Old Nov 12, 2010 | 05:44 PM
jetspeedz's Avatar
everything delivered including main shaft bearing, seal, and countershaft + mainshaft gear was 170 to my door
Old Nov 12, 2010 | 08:07 PM
jDMJeRk's Avatar
Originally Posted by jdmchinoCDN
dog box
For sure- you can't go wrong here! I daily drive mine and it gets me through VTEC way faster
boosted.da
Transmission & Drivetrain
Sep 22, 2009 09:50 PM
SPOOLINmatt
Oct 16, 2008 01:17 PM
White_EK49
Jan 15, 2006 09:54 AM
95GSRTT
Aug 11, 2004 07:16 AM
EH2LS
Jul 21, 2003 12:10 PM
