quaife
Old Jan 14, 2006 | 12:41 PM
White_EK49's Avatar
Default quaife
what are needed to swap LS quaife lsd to make GSR tranny compatible. Is a plug and play deal.
Old Jan 14, 2006 | 01:07 PM
vaporboy12's Avatar
Default Re: quaife (slow29)
i think you just need the final drive i could be wrong
Old Jan 14, 2006 | 01:14 PM
White_EK49's Avatar
Default Re: quaife (vaporboy12)
your talking about the ring gear or final drive off the 94-01 gsr
Old Jan 14, 2006 | 01:17 PM
White_EK49's Avatar
to clarify things up. I have a ls tranny with quaife and would like to use the quaife into the gsr tranny for better turbo gearing. What is needed to complete the changeover. DO i just swap out the lsd, final and bearing off my ls tranny and swap the gsr out right. any suggestion? thanks..
Old Jan 14, 2006 | 05:13 PM
matkeller's Avatar
if you have a gsr trans and you want to use your ls quaife it will work with a b16 ring gear which is a 4.40 same as gsr and you need to use the ls diff bearrings (sealed type) because the gsr diff bearrings (open type) won't work (have different spacing) don't for get to knock the bearring races out of the the gsr case if you use it
Old Jan 14, 2006 | 05:25 PM
ninesecrx's Avatar
Default Re: quaife (matkeller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matkeller &raquo;</TD></TR><TR><TD CLASS="quote">if you have a gsr trans and you want to use your ls quaife it will work with a b16 ring gear which is a 4.40 same as gsr and you need to use the ls diff bearrings (sealed type) because the gsr diff bearrings (open type) won't work (have different spacing) don't for get to knock the bearring races out of the the gsr case if you use it </TD></TR></TABLE>
True, but some GSR trans are actually set up from the factory with a sealed bearing so all you MIGHT need is just the ring gear.
Modified by ninesecrx at 6:45 PM 1/14/2006
Old Jan 15, 2006 | 09:54 AM
E Town DSM's Avatar
Default Re: quaife (ninesecrx)
I have seen both the sealed type and open roller type on a gsr trans depends on the year. I think early ones like 94-95 have the open roller type.
Manny1987
Transmission & Drivetrain
Mar 27, 2011 06:25 PM
SPOOLINmatt
Oct 16, 2008 01:17 PM
turbotime
May 2, 2006 10:15 PM
EH2LS
Jul 21, 2003 12:10 PM
DIRep972
Oct 24, 2002 10:16 AM
