keep blowing wheel bearing on passenger side help
Old Nov 7, 2010 | 02:51 PM
jdmcivicracer89's Avatar
Default keep blowing wheel bearing on passenger side help
alright i had a new wheel bearing installed about a month ago everything went fine til last night. i changed a axle out cuz i thought it went bad went for alil driv and the wheel bearing went out. grabbed the knuckle of my other car a ex and put it on my si. this is also a brand new wheel bearing. went to the starved rock meet today and the wheel bearing went out again. i dont think its bad luck that both went out like that. any clues wuts goin on here??
Old Nov 7, 2010 | 02:58 PM
Chiovnidca's Avatar
Default Re: keep blowing wheel bearing on passenger side help
So it started after you replaced the axle? Is it the correct axle? Is the nut tightened properly and staked?
Old Nov 7, 2010 | 03:03 PM
its a axle for a 2000 si which thats the car that i have.. the nut is tightened diwn properly as well. the bearing gets pretty bad after a short drive i mean u can move the wheel in and out a inch. how would a bad axle cause this though?
Old Nov 7, 2010 | 05:11 PM
2k.civic.si's Avatar
You sure you didnt overtighten that axle nut?
Old Nov 7, 2010 | 07:38 PM
Chiovnidca's Avatar
That's what can happen if the nut isn't seating all the way down clamping the bearing together. To get that loose something has to be off pretty bad.
Old Nov 10, 2010 | 10:36 AM
alright yea the bolt wasnt goin on far enought bad axle put new one on with new bearing and seems fine so far been alil over 200 miles
Old Nov 10, 2010 | 09:59 PM
Chiovnidca's Avatar
Glad you got it sorted out. That's one of those oddball problems that can crop up once in a while.
L2ILL
Oct 22, 2012 01:38 PM
jdmcivicracer89
10
Nov 7, 2010 04:48 PM
Dale_K
Oct 20, 2010 11:17 AM
HOODLOVER
Oct 26, 2008 07:24 AM
spets
Suspension & Brakes
Apr 5, 2008 05:31 PM
