91 civic hb, d16z6 motor/L3 tranny, needs throw out bearing, help?
Old Nov 7, 2010 | 12:00 PM
Beasty91Hatchy's Avatar
Default 91 civic hb, d16z6 motor/L3 tranny, needs throw out bearing, help?
whats the quickest and easiest way to do it?
91 civic hb
d16z6 swap
L3 tranny
Old Nov 7, 2010 | 12:01 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: 91 civic hb, d16z6 motor/L3 tranny, needs throw out bearing, help?
There is no quick/easy way to do it. Your engine/transmission combo is irrelevant. Remove your transmission and replace the throw out bearing.
Old Nov 7, 2010 | 12:07 PM
im asking if its eassier to pull the engine or to jack the car up and drop the tranny without the engine ...
im not a ****ing retard , by the way ...
Old Nov 7, 2010 | 12:15 PM
91siman's Avatar
you see you didnt make it clear man you said which way is easy and quick meaning that you want to do it fast and now. but the easiest for me was to jack the car and then drop the tranny.
Old Nov 7, 2010 | 12:21 PM
Echo 6's Avatar
i think the easiest way is to support the motor with something, remove the axles, take the mounts off the tranny & unbolt it from the engine. It should come out without too much trouble & you won't have to pull the motor.
I have done it that way before and it wasn't too bad.
Old Nov 7, 2010 | 12:39 PM
24TEN's Avatar
PHANTOM MENACE
Your original post:
Originally Posted by Beasty91Hatchy
Thread title: 91 civic hb, d16z6 motor/L3 tranny, needs throw out bearing, help?
91 civic hb
d16z6 swap
L3 tranny
Followed by:
You did NOT state those two options for comparison and nobody called you anything. You want a question answered, be specific. Ask a vague question you'll get a vague answer.
Old Nov 7, 2010 | 01:17 PM
thanks for this, im going to try it, if it doesnt work, ill just do it the other way, but i dont see it not working, looks like i have alot of room to work with down there, once jacked up on jackstands and stuff.
Old Nov 7, 2010 | 05:18 PM
DCRB's Avatar
if you're by yourself just pull the motor and trans through the top, that way you don't have to fight with the trans when you go to put it back on.
Old Nov 7, 2010 | 10:05 PM
i have atleast one good helper, and a half good one, lol.
shouldnt b a problem i hope.
Old Nov 8, 2010 | 12:32 AM
hatchet_honda's Avatar
might as well replace the clutch while you got everything apart...unless its damn near brand new.. youll kick yourself in the *** if it goes back soon after the release bearing change. if the bearing is bad im guessing the clutch hasnt been changed recently
Old Nov 8, 2010 | 11:56 PM
nah the ******* i bought it from put in a short shifter and stage 2 clutch and lightened flywheel(dunno how much lighter) , wellll, he didnt change the throw out bearing for some unknown reason, maybe he thought it was good still? idk.
Old Nov 9, 2010 | 02:41 PM
91siman's Avatar
That is retard Right there! yup. Replace the thing because at the end if it does give out you have to do the same proses all over and it suck doing it again then just replacing it!
Old Nov 11, 2010 | 03:59 AM
Foowee's Avatar
21 spline 190mm came in 88 crx/civics
21 spline 200mm came in 86-89 teg/79-87 prelude
20 spline 200mm came in 89 crx/civics
20 spline 212mm came in 90-00 non-b series crx/civics
21 spline 212mm came in 84-87 2.0L Preludes
19 spline 190mm came in 73-80 civics
19 spline 200mm came in 81-87 civics
19 spline 190mm came in 84-87 crx
24 spline 210mm came in 88-89 prelude
24 spline 220mm came in 90-95 prelude non-vtec
24 spline 225mm came in 94-99 prelude vtec
I think the cable n hydro throwout bearings are different. Go to Majestic honda's site n see if the part numbers are different between say a 95 ex and a 90 si...
Old Nov 11, 2010 | 11:28 AM
That EF's Avatar
go back to elementary school...
with a helper or not, i HATED fighting the trans to get back in...easiest way would be to pull the motor and do it. would be ALOT easier ha. get your flywheel resurfaced too.
Old Nov 11, 2010 | 12:37 PM
Foowee's Avatar
Guy's, are you dropping the front crossmember? Or are y'all wrestling the trans out with the radius rod/cm in the way? Disconnecting all the junk from the engine n pulling it is time consuming and unnecessary.
Old Nov 11, 2010 | 12:56 PM
That EF's Avatar
every time Ive pulled the trans i just wrestle it out.
racebum
Aug 18, 2008 10:11 AM
xxmastermindxx
Nov 14, 2006 11:07 AM
Shaun
Apr 8, 2003 07:49 PM
SUis1
Oct 22, 2001 09:03 AM
