Suspension & Brakes Theory, alignment, spring rates....
Bilstein B6/B8 Monotube INVERTED shocks
Old Nov 6, 2010 | 11:44 AM
Tyson's Avatar
Default Bilstein B6/B8 Monotube INVERTED shocks
saw these shocks from Bilstein and thought it was pretty interesting. looks like theres not too many common older civic/integra applications. but maybe the front EKs can be made to work. wonder if anyone checking in from europe has any experience with these shocks, on a honda or any other car.
Old Nov 6, 2010 | 05:36 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Bilstein B6/B8 Monotube INVERTED shocks
What is the benefit of having the piston body up top and the piston down at the bottom?
Old Nov 6, 2010 | 08:40 PM
92civiceg9gsr's Avatar
I do believe on some cars it has to do with unsprung weight to have inverted shocks.
Old Nov 8, 2010 | 05:39 AM
cruizinmax's Avatar
They are also generally used in McPherson strut applications due to the strut also performing the duty of the steering knuckle as well. The design is much stiffer than a conventional shock. That would also be why you do not see them for double wishbone cars as well.
mylament55
Honda CR-V & Element
11
Oct 25, 2017 08:54 AM
David123
Jan 30, 2006 09:28 PM
S.Celia
Dec 15, 2003 07:50 AM
Slow&Furious
Nov 20, 2001 03:45 AM
Jordan_4WS
Oct 8, 2001 02:25 PM
