H22 lacks power
Old Nov 5, 2010 | 08:33 AM
GearBangnAclude's Avatar
Default H22 lacks power ( Videos up)
Problem solved TY ALL
Old Nov 5, 2010 | 09:08 AM
Default Re: H22 lacks power
no replies yet where are all my H deuce deuce heads at????????
Old Nov 5, 2010 | 01:39 PM
ilikehonda's Avatar
check to make sure the TPS and MAP sensor plugs are not reversed. What ecu are you using?
Old Nov 5, 2010 | 01:41 PM
p13 stock ecu i got some vids a while ago just waitin on the upload then ima post. I took a few runs some hitting vtec so from a dig some in 2nd low rpms where the problem persists
Old Nov 5, 2010 | 02:59 PM
First off here is my Bitch
Old Nov 5, 2010 | 05:18 PM
hehu's Avatar
i have that problem to. but my problem is the timing of the cam.
Old Nov 6, 2010 | 04:25 AM
ilikehonda's Avatar
ive got an idea. fix the fuel filter leak and fix the Check engine code. if you have a code it will throw the ecu into limp mode, pull timing and add fuel.
Old Nov 6, 2010 | 06:36 AM
Libertariat's Avatar
Ek Forever y0!
this.
Old Nov 6, 2010 | 11:17 AM
chikin pickle's Avatar
you TPS should read arbitrarily close to 5 volts at WOT. Replace it.
Old Nov 6, 2010 | 11:57 AM
ok so i tested another tps sensor and im still not getting 5 v at WOT cud it be my wiring is fuked???? Im have one more TB with Tps on it ima test that one too and see
Old Nov 7, 2010 | 08:56 AM
ilikehonda's Avatar
Originally Posted by GearBangnAclude
If u read u wud see that i pulled the code already dont just watch the videos READ.... Fuel leak is fixed test drove same symptoms came back ran some more diagnostic and i convinced i need to adjust my tps since it reading .3v close and 2.5-2.6v @ wot on a 9v setting, but i still get code 12 with a known working egr and even when i run the test and gnd the b terminal while powering A (looking for vacuum on the Gauge) it blows my # 2 15A fuse in underdash F/b so something is fuked up there
I read your post. In the video you have a check engine light. Is the light still on? Have you reset your ecu?
Old Nov 7, 2010 | 07:44 PM
nus_dogg's Avatar
I don't think the IM part affects your powerloss. I would look into the exhaust part. But, I'd do a cyl leakage and compression test just to make sure the internal stuff isn't the problem.
Old Nov 8, 2010 | 05:26 AM
ilikehonda's Avatar
take the bottom half of the header off...go drive it...see if the power comes back
Old Nov 8, 2010 | 07:06 AM
nus_dogg's Avatar
Run open downpipe!
Old Nov 8, 2010 | 09:34 AM
will try that but i dont think my neighbors like me as it is especially since im always tearing up my block so now there definitely gonna hate me
Old Nov 12, 2010 | 09:34 AM
FIXED incase anyone was wondering or has similar issues it was my ignition timing
Old Mar 29, 2011 | 09:13 PM
elvisvsdcsniper's Avatar
hey i was wondering if your problem started after you got your im. i recently installed a skunk2 im and tb made sure to connect all my sensors back and 10 minutes later the cel came on since then my car is so slow. I would appreciate it if you can help me out
thanks
Wreckleford
Nov 12, 2012 10:23 PM
JDM_is_overrated
Aug 15, 2008 03:04 PM
tSuperbike69
Oct 7, 2005 02:23 PM
Catman316
15
Apr 14, 2005 03:31 PM
IHateJDM
May 30, 2004 03:53 PM
