Transmission & Drivetrain Gearboxes, Differentials, Clutches
Difficulty shifting into first and then second
Old Nov 1, 2010 | 07:34 PM
mr_munro's Avatar
Default Difficulty shifting into first and then second
Hello, from stationary, it feels notchy when shifting into first gear and a bit difficult shifting into second once rolling and it is also worse when the car is cold, however all the other gears are fine. My trans oil has not been changed in about 22000 miles so im going to start with that, but if it was my oil wouldnt it be difficult in all gears?
There is also no noise/grinding/crunching from the gear box at all.
Engine + trans has about 150 000 miles on it.
There is also some difficulty when down shifting to these gears also.
Just wondering what the other possibilitys are, maybe clutch, master cylinder, save cylinder or in actual fact the gear box.
Thanks
Old Nov 1, 2010 | 08:37 PM
mr_munro's Avatar
Default Re: Difficulty shifting into first and then second
no one?
Old Nov 2, 2010 | 11:52 PM
mr_munro's Avatar
Old Nov 3, 2010 | 08:19 AM
mr_munro's Avatar
hellpppppp
Old Nov 9, 2010 | 03:36 PM
mr_munro's Avatar
Old Nov 9, 2010 | 05:14 PM
dntnedvtec's Avatar
seems like you need a new tranny.
Old Nov 9, 2010 | 09:29 PM
mr_munro's Avatar
if it was a bad tranny would it be hard to shift when the car is off? because it is actually pretty easy so mayve it has something to do with my clutch?
Old Nov 11, 2010 | 02:12 PM
jim94hatch's Avatar
I kinda have the same problem. Only when i am sitting with the car running and i go to put it in first is starts moving sometimes with the clutch pedal pushed to the floor. could that just be like an air bubble in the line? Maybe dirty Fluid? If so, what is the best way to flush all the old fluid out and put new in?
Old Nov 16, 2010 | 09:50 PM
mr_munro's Avatar
yea great help HT is.... (N)
Old Dec 29, 2010 | 09:19 AM
mr_munro's Avatar
bumpppp
Old Dec 29, 2010 | 01:11 PM
sh!ft's Avatar
Who the fack changed my title?!
how old is your clutch? have you EVER serviced your transmission internally before? seems like it COULD be your sliding hub assembly, or your shift fork had worn down to some degree.
Old Dec 29, 2010 | 07:13 PM
GoldMember74's Avatar
since it seems to be temperature related like u said, my best guess is it's something internal...shud do all the visible check first anyhow to rule out everything else like worn out clutch, leaking clutch pump, etc...after a while oil sludge could be accumulating and jamming this small cylindrical rod called shift piece shaft which is supposed to be able to move smoothly thru its assembly...its serviceable, but u hv to open up the gearbox, find it and clean it...
not sure if this diagram comes out or not, if it does, it's item 3 & 8:
http://www.hondapartsnow.com/diagram...tec-460663.png
...hope that helps...
Old Dec 29, 2010 | 07:47 PM
Natural Aspirations's Avatar
My EP does the same thing when it is cold.
I believe it is related to the Hydraulic system. Only when it is cold and low gears. Try flushing the fluid and bleeding the fluid.
Old Dec 29, 2010 | 11:08 PM
mr_munro's Avatar
yea it only whens when its cold basically, im gonna change my clutch and tranny fluid and see how i go. thanks for everyones input
algerian74
Jan 30, 2010 08:01 PM
gsr90
Nov 18, 2008 02:12 PM
abeaujuin
Nov 12, 2004 09:28 PM
91_2.0_Si
May 20, 2004 07:05 PM
eg_nezay
Feb 5, 2002 10:04 AM
