HELP! GEAR PROBLEM
Old Feb 3, 2002 | 08:20 PM
eg_nezay's Avatar
Default HELP! GEAR PROBLEM
Its difficult to put my car into 1st and 2nd , but its fine for 3rd,4th,and 5th. whats wrong??????any opinions???
Old Feb 3, 2002 | 08:23 PM
B18CRacer's Avatar
Default Re: HELP! GEAR PROBLEM (eg_nezay)
change your transmission fluid?
Old Feb 3, 2002 | 08:27 PM
eg_nezay's Avatar
Default Re: HELP! GEAR PROBLEM (B18CRacer)
I just got my swap done and saw them put 2qrts in . Do you think it needs more??
Old Feb 3, 2002 | 11:18 PM
B18CRacer's Avatar
tranny oil is fine. you burn out to much on first and then you shift in 2nd to fast?...I dont know.
Old Feb 3, 2002 | 11:29 PM
threatcon13's Avatar
New User
no...thats probably not the cause. maybe synchros? or tranny/clutch is goin out....how many miles on the car? have you been shifting hard on it? something is definitely wrong..like my friends car..where 5th was hard to get into..now all gears are hard to get into.
Old Feb 4, 2002 | 05:57 AM
maggsgsr's Avatar
Default Re: HELP! GEAR PROBLEM (turbo01gsr)
Could be a slave cylinder
Old Feb 4, 2002 | 10:18 AM
eg_nezay's Avatar
The engine suppose to have 25-35k miles. This morning I was able to put it into 1st but not into 2nd. I can put it into 2nd but I have to shove it in there.Also turbogsr, what did youre friends car and up having?
Old Feb 4, 2002 | 06:16 PM
New User
dont know yet mang...but basically his clutch is pretty much out...so we'll find out when we switch the clutch out if that was the problem.
Old Feb 4, 2002 | 08:54 PM
eg_nezay's Avatar
THANKS FOR ALL THE INFO GUYS!
Old Feb 4, 2002 | 09:00 PM
eg_nezay's Avatar
Im getting it checked out tomorrow morning, so let you guys know what it ended up being.Thanks again!
Old Feb 4, 2002 | 09:50 PM
deMad10's Avatar
What about linkage?
Old Feb 5, 2002 | 10:04 AM
93LSivic's Avatar
Shifter forks are a common problem in sohc trannies. Transmission oil capacaties for sohc is 1.9 quarts. For dohc its 2.3 quarts. You may be low if you have a dohc motor.
itr1244
Sep 29, 2014 12:52 PM
gsr_b20b
Jul 17, 2009 03:53 AM
misoshiru_akira
Feb 26, 2007 06:29 PM
95GSRTT
Aug 16, 2004 04:34 PM
HavokB18
Jul 26, 2003 05:32 PM
