D15b turbo engine how?
You're going to have to use the search feature to educate yourself. This stuff has been covered 1000 times.
Here is over 500pgs of Dseries set ups -> https://honda-tech.com/forums/showth...t=single+slams
Do yourself a favour and read through the FAQ at the top of the page. It will answer a lot of the starter questions you have. If you have unanswered questions after doing your homework, then ask and we will be glad to push you in the right direction.
One piece of info to start you on your way: Dont set goals in terms of PSI as its an arbitrary measure...instead, set a power goal. Power creation can vary widely at X psi from one turbo to the next...or even one setup to the next (using the same turbo). If you search what boost actually is, you'll begin to understand why this is the way it is...
Do these things really work for increase in hpnthe electric one kinda makes a little sense to me
http://item.mobileweb.ebay.com/viewi...id=27884699177
http://item.mobileweb.ebay.com/viewi...id=85635622292
ok so i already did some research and know what i need like turbo manifold piping intercooler etc... only thing im stuck on is that with more air you obviosly need more fuel but im not sure how to get it? will bigger injectors work? how can i do it?
Have you read the Single Slams thread at all? Like I said there's over 500pgs of set ups and most included this info. For example:
-d16z6 .20 overbore stock sleeves
-cp 9.1.1 pistons
-eagle rods
-acl bearings
-arp studs
-tial 38mm wg
-bored stock tb
-stock head
-zex 59300 cam
-rc 500cc injectors
-255 lph walbro inline
-thermal IM gasket
-BMC elf mani
-precision gt3251e turbo
-"RFL" bov
-crome
-zeitronix wb
-3.5 bar map
-cp 9.1.1 pistons
-eagle rods
-acl bearings
-arp studs
-tial 38mm wg
-bored stock tb
-stock head
-zex 59300 cam
-rc 500cc injectors
-thermal IM gasket
-BMC elf mani
-"RFL" bov
-crome
-zeitronix wb
-3.5 bar map
beginmyhonda
11
Dec 19, 2011 04:21 PM
vtak2nr
Engine Management and Tuning
Nov 27, 2011 06:02 AM
