Borg Warner S362 vs PTE 6262 DBB Billet
Old Oct 27, 2010 | 08:42 PM
dubseven's Avatar
Default Borg Warner S362 vs PTE 6262 DBB Billet
Has anyone done any testing? Currently have an S362, debating switching over to a 6262. Is there any comparison data??
Old Oct 27, 2010 | 08:50 PM
bobo-jenkins's Avatar
Default Re: Borg Warner S362 vs PTE 6262 DBB Billet
im sure with a few minutes of serching google/here you could find flow charts....
Old Oct 27, 2010 | 09:26 PM
dubseven's Avatar
Well, has anyone done any dyno testing?
Old Oct 28, 2010 | 05:47 AM
TheShodan's Avatar
Moderator
They have, but you're not going to see a back-to-back comparison of the two on exactly the same platform. Both turbos are highly utilized but may be from two different kinds of buyers. Honestly, you'd just be making a lateral move with what you have. If it ain't broke, don't fix it.
Old Oct 28, 2010 | 05:49 AM
dubseven's Avatar
So you do not think spoolup time or transient response would be improved?
Old Oct 28, 2010 | 05:52 AM
TheShodan's Avatar
Moderator
Depending upon which Housings/wheels are on your S362, not really. You could use the same money, and convert your S362 with a new backplate and S200 housing, and create a S262 which is more responsive than the much larger cover. If you have the .70A/R, your turbine wheel is larger than the 6262 anyway, and you could still keep that or swap down to a slightly smaller 74mm inducer. But again, it may cost a couple bucks (few hundred)
Otherwise, no. not really. won't be that improved, at least from my experience with them
Old Oct 28, 2010 | 05:54 AM
dubseven's Avatar
Its a divided T4 .8x housing right now. Trying to get a little more response out of the motor.
Old Oct 28, 2010 | 05:55 AM
TheShodan's Avatar
Moderator
Oh wow.. Ok. that's using the 80mm exhaust wheel. PM me. I'll give you some options.
Old Oct 28, 2010 | 06:08 AM
dubseven's Avatar
PM sent
Old Oct 28, 2010 | 06:45 AM
civgt28's Avatar
i have an s362 as well, who would i contact in getting the cover and whatnot to create this
s262. would there be a very noticeable difference in response? thanks
Old Oct 28, 2010 | 07:27 AM
TheShodan's Avatar
Moderator
PM'd
boostedteg4dr
Apr 4, 2014 09:03 PM
Norcalstoppy
Sep 28, 2005 06:48 AM
allm0t0rsir
Apr 6, 2004 01:02 AM
92TypeR
Honda S2000
Mar 8, 2004 02:01 PM
