Turbo Exhaust header
I was curious on what is the best turbo exhaust manifold to get. I will be using a Gsr head with head work done like port & polish, and 3 angle valve job and will be running a Garrett 60-1 T3/T4 Turbo. Like i said I was curious on what turbo exhaust manifold to get. Thanks.
You're going to have to do some searching as there are going to be many different opinions as to the "best" manifold.
Other aspects of your build will determine what manifold you want to some degree. Full or half rad, AC or non, etc. I went with a Blox mani as I am running full rad and AC. Tubular / equal length manifolds with a full 3" DP will typically yeild higher #s, but are not usually AC friendly and often require a half rad.
Start by finding some that you like and then researching others experiences with that brand on here. Cheap chinese manis tend to fail due to poor quality. Another reason I went with the cast Blox unit was the lifetime waranty. Some older manifolds have poor waste gate placement resulting in boost creep/spikes. GL
im using a top mount, just be careful with those, it might not clear and you will have to cut your hood
i would have gone ram horn style if i didnt have to buy another exhaust, downpipe, etc
tito1324
Mar 6, 2017 10:16 AM
jdm_vtec
Jan 22, 2008 03:29 PM
matto2413
May 22, 2006 06:00 AM
