Hood latches but doesnt close all the way on drives side! What to do!?!
i just got my integra, the hood latches but it doesnt shut tottally on the drives side, the hood hits the turbo and it wont shut fully
i was wondering what options you guys would recommend, i was thinking a small hood scoop or cowl but i cant find one
help is appreciated
help is appreciated
figure out a way to relocate it or cut a small hole in the hood so that the turbo will stick out. have seen that done a few times before and i think its pretty cool. only thing is you wont be able to drive in the rain.
find someone to fabricate you some piping so you can reposition the turbo. thats about all i know to tell you man. either that or weld you a scoop. but the scoop will look like do do unless done right.
i need help! ahhh i need to drive it
im thinkin weld on a scoop for the mean time, and then getting it reloacted and then just buying another hood
if it's just hitting the skeleton part of the hood, I'd cut that out. And there'd be no hole visible from the outside. Could also try the hood tilt to give you some more space.
you can see how this s2k guy cut the recessed part of the hood, cutting around the skeleton
yeah put some spacers where the hood is bolted to tilt the hood a bit in the back. thats the cheapest way i could think of going about it...
it didnt clear with hood pop, so i got rid of the top mount =((((( and bought a ram horn manifold
Boostless97Lude
Sep 7, 2002 09:04 AM
